SATOH S-650G AND OTHER MODELS
SAM
05-13-1998 05:58:43
DOES ANYBODY OWN OR HAVE INFO ON SATOH S-650G
OR OTHER SATOH TRACTORS ?
Dave Sobczak
11-18-1999 21:34:06
 Re: SATOH S-650G AND OTHER MODELS in reply to SAM, 05-13-1998 05:58:43
Satoh S-650G Parts
Below is what I have been able to find for parts so far in the normal automotive market. The following ignition parts were all purchased from NAPA for a total of about $52.00. Not bad considering Homestead Tractor wants $139.00 for a tune up kit.
1.) Plugs = Champion N4C (They use a stocking number now and that is 803)
2.) Ignition wires = NAPA Belden, 7MM 4cyl Part # 700172 (universal, but excellent match)
3.) Distributor cap = NAPA Echlin Part # EP710 (says it's from a YALE Forklift Truck 1971-73 with Mazda engine).
4.) Rotor = NAPA Echlin Part #EP710 ( same forklift as distributor cap)
5.) Point contact set NAPA Echlin Part # CS360 ( These are from a MAZDA RX3, 1971-73) The Condenser is from the same Mazda RX3 (I do not have that part number).
6.) Service manual = from this site PN SA-S-650G, $39.95 call 1-800- 443-0625 and ask for On-line orders. The person I talked to said he could also get rebuilt starters and alternators for Satoh's.
7.) Parts Manual = Homestead Tractor has one available for $49.95 (number below)
8.) The Motor is a Mazda Engine 60.2 cu. in.(986cc), I have not found an engine match in a Mazda car or truck yet. I've heard of some partial success found with matching some parts to a 1,136 cc engine from a Mazda truck (probably in the 1971-73 area). The motor was definitely used however in Yale forklifts from 1971 to 73 that had a gas Mazda engine.
Here are all the numbers I have found that claim to be able to supply some parts (or may know of sources). You'll have to check them out yourself.
� Homestead Tractor = 760-240-1610
� Ted at RM Wade Co. = 503-641-1865
� Stull Co. = 1-800-229-7885
� Charlie Livermoore (Someone recommended his name to me) = 716-526-5827
� Sherry = 1-800-445-3943
� Lowe's Tractor = 812-663-8928
I'm looking for a valve cover gasket for the engine and exhaust manifold to exhaust pipe gasket. Any other questions my E-mail is ([email protected]) Good luck, keep letting everyone know if you can find S-650G parts through normal automotive channels, otherwise they are very $$$$$$. Dave
Dennis Woyame
01-04-2005 15:39:32
 Re: Re: SATOH S-650G AND OTHER MODELS in reply to Dave Sobczak, 11-18-1999 21:34:06
I'm trying to rebuild a carburetor on a Satoh S-650 G and found out that the parts are very expensive. Has anybody found any reasonable parts for carburetor or possibly replacing the whole carburetor with a similar carburetor? Thanks.
GuessAndGoFarmer
05-09-2005 13:50:52
 Re: Re: SATOH S-650G AND OTHER MODELS in reply to Dennis Woyame, 01-04-2005 15:39:32
I"m also looking for info. on a rebuild kit for my satoh 650-G. Have you been able to find the kit? Where?
PHIL BOWMAN
02-19-2005 05:57:59
I HAD MY CARB AND WATER PUMP REBUILT AT HITE AUTOMOTIVE IN COLUMBUS,OH WWW.HITEPARTS.COM
starr miner
08-25-2005 17:10:04
 Re: Re: SATOH S-650G AND OTHER MODELS in reply to PHIL BOWMAN, 02-19-2005 05:57:59
we have a satoh s-650g ser no 130414 and would like to know what year it is and where to get infomrmation on it. thanks for any help you can give me.
statt
Joe Paschal
05-04-1999 08:37:49
: DOES ANYBODY OWN OR HAVE INFO ON SATOH S-650G
: OR OTHER SATOH TRACTORS ?
I have a Satoh s650-g. I am interested in carb.
I just received info from Homestead tractor.
Looks like they may be able to help with parts for
any one interested
Ron Crammer
05-07-1999 10:20:15
 Re: Re: SATOH S-650G AND OTHER MODELS in reply to Joe Paschal, 05-04-1999 08:37:49
I have a 650g and have been pleased with it. I am experiencing overheating problems. Thermostat checks out ok, head was reworked a year ago. I could use a timing spec., on this machine and I am going to have the radiator redone. Any advice would be greatly appreciated. Incidently, I run a 6' finish mower and overheating occurs no matter what gear I run in...Thanx in advance for any help.
John
07-18-2003 11:24:11
 Re: Re: Re: SATOH S-650G AND OTHER MODELS in reply to Ron Crammer, 05-07-1999 10:20:15
This is a late addition, but my 650 G needed to have the radiator removed and "boiled" out to get all of the chaff from the radiator fins. Since then it runs cool.
Hopes this helps.
Steve Blake
06-28-1999 17:57:46
call 1`919 821-5937
Ron Crammer
04-19-1999 09:18:49
I have an s-650g. I just had the head rebuilt and have a problem with overheating, I could use a timing spec. It has been a project since I acquired it, but it does work hard. I have a 4' plow blade and was able to dig out of the blizzard of '96 in northern NJ.
Bruce Hoffman
05-13-1998 11:17:29
I own a Satoh 650g, it is a good liitle tractor.
It has a great 3pt will lift alot more than the
tractor weight can handle. The parts for these
tractors ARE high. I kept the maintance on this
guy up, in hope that nothing fails. It's rated
at 25hp, let me know if you have more specific
questions.
-Bruce
Ron Crammer
04-19-1999 09:30:37
 Re: Re: SATOH S-650G AND OTHER MODELS in reply to Bruce Hoffman, 05-13-1998 11:17:29
: : DOES ANYBODY OWN OR HAVE INFO ON SATOH S-650G
: : OR OTHER SATOH TRACTORS ?
: I own a Satoh 650g, it is a good liitle tractor.
: It has a great 3pt will lift alot more than the
: tractor weight can handle. The parts for these
: tractors ARE high. I kept the maintance on this
: guy up, in hope that nothing fails. It's rated
: at 25hp, let me know if you have more specific
: questions.
: -Bruce
I have a 650g, I found manuals thru a company called Yesterdays tractors on this very site. Good luck and Bruce is right, keep the maintenance up on this puppy, parts ain't cheap!!
bill baldwin
05-02-2000 17:56:50
 Re: Re: Re: SATOH S-650G AND OTHER MODELS in reply to Ron Crammer, 04-19-1999 09:30:37
thanks everyone,forall the info it has been helpfull.I am looking for a waterpump for a s-650g .WE have a loader on ours its great!
Floyd
08-20-2004 11:47:43
 Re: Re: Re: Re: SATOH S-650G AND OTHER MODELS in reply to bill baldwin, 05-02-2000 17:56:50
the water pump can be gotten from a mazda dealer I got one ,used a 1970 mazda pu truck 1.6 motor as the one to get saved $800.00 over the satoh dealer cost
