Tractor Transporting Discussion Forum
Thanks for the Advice
Dave (Tx)
08-31-2007 11:56:51
Thanks for all the advice on hauling. I checked the Texas laws specifically and they are actually very vague regarding securing cargo. The "device" has to have a rating of 1/2 the cargo load (assuming you're using 2 "devices"). A listing of acceptable devices include wire rope (whats on a come-a-long) strapping (synthetic webbing), chains, polyester fiber rope, nylon rope, and manila rope just to name a few.
My come a longs are rated at 6000 lbs. each (I use 2 in front). My strapping is 3 in. and rated at 10,000 lbs. each and DOT approved (at least according to whats stamped into the webbing itself.)
As far as brakes I plan on looking into that. Seems like a good thing to have and I'd like to see how hard that would be to put on my double axle 16 foot flatbed. The law in Texas is that any trailer hauling over 4500 lbs. must have brakes. I believe I'm a little below that. Trailer maybe 1000, 8N 2400, and mower 300 you're looking at around 3700 lbs.
I am going to start supporting the rear of the trailer to prevent the truck from being lifted when loading/unloading. Was thinking of using heavy duty aluminum car jack stands. My son had the brite idea of using a trailer drop leg jack on the rear - bolt it on and then just crank it down every time.
I think this forum is great for helping people make safer decisions regarding pulling a trailer and hauling tractors. It's given me a lot to think about.
Oldmax
09-07-2007 18:52:14
 Re: Thanks for the Advice in reply to Dave (Tx), 08-31-2007 11:56:51
third party image
I like the jacks on TyTX Trailer real well . If was doing again thats the way I would go but here is the jacks on my trailer , Made from jacks from a Truck camper Stortend and welded to back of trailer . I also added covers for lights & moved Plates to back of fender after ripping them off on Gate Post . Sorry for junk on trailer
Kent in KC
09-20-2007 07:26:44
 Re: Thanks for the Advice in reply to Oldmax, 09-07-2007 18:52:14
All good ideas. Now I know what (else) I'll do this winter.
RustyFarmall
09-01-2007 11:49:12
Dave, you might want to weigh that trailer. I'll bet it is much closer to 2,000# than it is to 1,000.
Dennis Benson
08-31-2007 17:57:33
If you want to make the law more vague it also says that if the load should come loose it should not cause you to loose control. I won't even go into how fuzzy things get if you get a DOT number, when they come out to do their assessment. They didn't even look at the truck, just ask a bunch of Yes/No questions. When you're your own mechanic you get to do your own inspections, and when you are the owner you get to certify yourself.
markloff
08-31-2007 17:35:20
 More Advice in reply to Dave (Tx), 08-31-2007 11:56:51
Dave,
Don't even bother putting brakes on one axle. If your going to do it do both. I believe most states require both axles anyways and if your going to be buying controllers and doing wiring you may as well do them both. Also get the adjustable controller so you can set the braking amount on the trailer depending on the amount your hauling. You can pretty much turn it off when your empty and save on your trailer brakes. Just don't forget to crank it back up when you load up.
I've done a few panic stops over the years hauling only 3,000 or less. The problem is when you lock up the back tires of the truck it will want to jack knife if the trailer isn't braking it's own load. The last thing you want as you loose steering long before that happens and a split seconds worth of steering goes a long way in accident avoidance. I know you Texans like to live life on the edge but someone from MN may be visiting and not be aware of this little fact. BE SAFE
Mark
TyTX
08-31-2007 14:54:59
 Loading Jacks in reply to Dave (Tx), 08-31-2007 11:56:51
third party image
Here's a pic of what I had put on my trailer. Real handy and they are always there when I need 'em.
They would be easy to make and do yourself if you can make sparks and glue metal.
