Tractor Transporting Discussion Forum
DOT issues with S10 Chevy (LONG)
Doug in Illinoi
10-06-2007 21:51:45
OK, I started the whole DOT posting quite a while back. From what I have gleaned I feel I would be well within legal rights to to get my grandpa"s F14 Farmall back in Nebraska with my two axle homebuilt trailer behind my 2001 Chevy 2500 4x4. Now, more food for thought. I have a stepson who is in Iraq working for a private contractor as a firefighter, he was Air Force Sargent before doing same job, but money better now. Anyhow, he found a 92 S10 4x4 on the net about 30 miles from here he had me buy for when he comes back in December for a couple months. Will be in his brother"s name in case anything does go wrong in Iraq along with fact better truck than much newer 2wd not stout enough to pull fishing boat out of the Illinois river without difficulty. This 92 S10 is now a 5.7 fuel injected V8 5 speed, or for us old timers, a 350 converted to throttle body injection. It has all been done correct, have hooked the bumper pull behind it, with the mild cam and the suspension work the S10 has had, pulls the trailer at least as easy as the 2500 and stops almost as easy. I have the advantage of 4 wheel disk brakes. On a BIG load, obvious 2500 advantage. Anyhow, with a 6050 lb S10 pulling a 3500 lb fishing boat, will still be below the 10K DOT. This IS a commercial fishing boat, with the barrels set up in the back of the pickup to take the fish to market also, will this one need a DOT number? Also, would I be better off to borrow this to get the F14 as it makes in excess of 15 MPG as opposed to the 10 or 11 the big one gets pulling any trailer? Thanks, Doug
davediehl@hotmail.com
10-07-2007 08:27:43
 Re: DOT issues with S10 Chevy (LONG) in reply to Doug in Illinois, 10-06-2007 21:51:45
I think john in la covered this. The one thing that I will add is that IF you travel out of your home state, you are under DOT regulations on anything over 10,000 expecially with commercial plates. Again, your chances of having a problem may be slim to none, it would be one of those "Sucks to be you" if you were stopped. Without a doubt, it could be one expensive ordeal.
john in la
10-07-2007 05:45:45
Doug; You have several questions in this post so I hope I cover all of them.
The rules are fairly simple if you break them down. If you are over 10,000 or can weigh over 10,000 lbs and it can be considered a business you need a DOT # in some states and to cross any state lines.
So you can move your grandfathers tractor anywhere you want with any size truck you want. The truck; trailer; and load would have to be in your name or the name of a close family member such as your son. The rig would have to be licensed for personal use and used for this purpose 100% of the time. In other words if your son owned a 2 ton truck that he used in a business that did not need a DOT# because he stayed in the state all the time; You could not borrow this to go out of state even though the move is personal. The truck is a business truck. The place you can get in trouble with bigger trucks out of state; is it is hard to explain that you use a 2 ton truck as your personal grocery getter.
The truck and boat is a business. It is under 10,000 lbs but very close. It is most likely rated at over 10,000 lbs though to account for load weight. And this is a fine line because we are suppose to use rated weight not actual weight. Per the link a few weeks back Ill does not require DOT #'s on in state trucks. So your son could use this rig in the state with no problem. I do not know your state laws but here he would need a in state commercial tag for the truck since it is a business. Now if you ever took the rig out of state you may have problems because it may be RATED at over 10,000 lbs and this would put you into the DOT # class.
Since your son's truck will most likely have a commercial tag you would not be able to borrow it for the grandfathers tractor move because once again the truck is for a business and you will be going out of state; and most likely be over 10,000 lbs with the tractor loaded.
Now the above is the law. BUT if your son's truck looks personal; you could most likely get away with using it with no problems for your tractor move. It is not like they stop ever truck that crosses the state line and ask to see registration and such; unless you plan on going to AZ. Them boys are strict out there. Every car; truck; motor bike; horse; is stopped and inspected before it is allowed in the state.
But if you were in a accident and someone is hurt things may get real sticky when a lawyer finds out the truck is really a commercial truck and you were out of your state with it.
Doug in Illinois
10-07-2007 18:17:49
 Re: DOT issues with S10 Chevy (LONG) in reply to john in la, 10-07-2007 05:45:45
John:
I have been in this post long enough I trust you and Dave to tell the truth. Would like to talk to you and or Dave off forum. Can you email me with contact info, don't know if my private email shows or not. Will reply again if not. I did actually go on line to DOT and have a DOT number, emailed my insurance company and explained situation just tonight. I am more than willing to be in full compliance, my insurance (AMICA) is aware my 2001 2500 is farm use. Just made them aware of the possibility I may need DOT insurance. State of IL (ICC) sent me a letter about a week ago asking info for the UNIFIED CARRIER REGISTRATION. Will admit DOT number here, as you could find anyhow, I am 01616565. So, how do I do what is really right? Even the IL form is asking the number of trailers. I only have one truck, but could answer as many as 5 trailers. One 3 axle flatbed, farm plates. One livestock 3 axle, needs to go away, hauls horses and hay. One 2 axle University of IA built 12 flat 4 dovetail two axle. One 2 axle open top trailer, horse. One pickup box trailer still in Nebraska. Please just walk me thru what needs to be done, want to be legal, but if it means I will have to spend an extra 500 or 1000 a month I can't afford it. Doug
john in la
10-07-2007 20:07:49
 Re: DOT issues with S10 Chevy (LONG) in reply to Doug in Illinois, 10-07-2007 18:17:49
I sent you a e-mail with my contact info.
10-07-2007 19:09:32
It looks like the only thing missing is the insurance information. You could/should receive a call from your local motor carrier enforcement officer for a physical inspection of your equipment soon. They like to get this done within the first 6 months of the application. Doesn't cost anything, they just want to verify the equipment and that its in good repair.
10-07-2007 19:02:44
My email is listed in every post. Feel free to use it anytime.
Grizz
10-07-2007 17:44:25
I pull my skid loader with an 03 Chev 2500HD. I get pulled over by DOT and they ask for my DOT #. I tell them I don't have one, didn't know I needed one.
So I fill out the crapp and get one. Fine and dandy.
Get pulled over again, gladly offer up my DOT#. Robocop says I don't need one since the PULLING vehicle is not rated for over 10K even though I had my 12K tandem trailer on, as always.
Those sonsabitches don't know what the law is from one minute to the next so don't feel bad if you can't figure it out.
I went for 25 years and never got a second look. In the past few years I've been caught in their web SEVEN times. Even the local cops have their own DOT inspectors now. We call them fundraisers.
They pick you apart till they get some good fines on you and off you go. My lights and breaks always work but they just continue on till they make something up.
john in la
10-07-2007 19:55:08
 Re: DOT issues with S10 Chevy (LONG) in reply to Grizz, 10-07-2007 17:44:25
Like I said the rules are simple if you break them down but you really need to study how they affect you.
The best thing I can suggest to you is know the law as it affects you and follow it.
A pickup can pull a semi trailer if you can find a safe way to hook it up and still not need a DOT #. It goes by the weight rating of your truck; and hooking a to large trailer did not raise that rating it only cut your load carrying capacity because the trailer weighs so much more.
Now by knowing this you can tell the next officer that ask for a DOT # your truck is not rated for over 10,000 lbs so you do not need one. If he proceeds to write a ticket ask him to call his supervisor on the spot to clear it up.
Doug in Illinois
10-07-2007 18:40:24
Grizz:
Understand totally. Think all any of us wants is a clear right and wrong. If 10K was enforced for all, I would not have a problem with it as the insurance companies would know it as the law of the land. BUT, I am not one to make trouble, however, I could bring down no less than 5 lawn mowing companies for DOT 10K and two more lawn companies hauling away scrap in 3 axle dump bed trailers. Could also bring down 4 scrap metal haulers crossing the state line at Ft Madison using 2 axle trailers much worse shape than mine. NO lights left, no brakes, 3 cars high. I just am not one to cause trouble, BUT????
