Tractor Transporting Discussion Forum
Chevy 454 Hard Starting
Jerry Eime
10-03-2007 19:48:23
Is anyone having the problem of 454 motor being hard starting after it is hot. It only does it when its hot and I have to crank and Crank and finally it will start and puff out the most rich colud of smoke. I have been told to change the fule pressure reguator. I still need to do that. But I was just courios to see if it has happened to others. It is in a 2000 Chevy 3500 HD Flatbed. Thanks
Jerry Eime
10-04-2007 06:28:50
 Re: Chevy 454 Hard Starting in reply to Jerry Eime, 10-03-2007 19:48:23
Thanks, I will try that.
ericlb
10-03-2007 21:07:44
i havent seen this one in a couple of years, but i remember it well, im assuming this 454 is a few years old, all big block chevys have a starting problem when their hot, this is caused by the factory exhaust running too close to the starter motor, gm came out with a kit in the mid 80's directed at stopping this problem it consisted mainly of a heat shield installed between the exhaust and the starter you might check with your local dealer and see if he has any left or knows where some might be,
npuller
10-03-2007 20:28:48
HI Jerry .you allso may have injectors leaking.had that hapen to my 98 454 allso had the regulator problem.to check injectors remove upper manifold and you can see if the inj is leaking
