Tractor Transporting Discussion Forum
john in la
Germ
10-02-2007 19:30:12
In one of your previous posts, you mentioned Pre Pass. I've seen the signs and know it for the big rigs, but how does that work?
john in la
10-02-2007 20:23:46
 Re: john in la in reply to Germ, 10-02-2007 19:30:12
The company applies for and gets a windshield mounted computer chip.
third party image
There are 3 readers mounted above the road by a scale. When the truck passes the first reader it logs the company; truck #; ect ect.
As the truck comes to the second reader it sends the driver a green or red light; that tells him if he needs to stop at the scale for a random check.
If he gets a green light he can bypass the scale and the third reader records this.
I really do not know the charge for the service but I have heard some say they pay XX per month and others say they pay XX per scale passed.
It was set up to allow know companies with good records to by pass a scale. This cuts down on wrecks as the slow moving truck has to re-enter after weighing at the scale.
There are still random checks of weight to make sure you do not use pre pass as a way to run over weight.
One of the scales I pass almost daily has pre pass but it is of no good because they have also installed a weigh in motion scale in the road that weighs your truck at 70 mph; and then gives you a OK to pass the scale on a road sign. So pre pass or not a lot of trucks get to bypass this scale.
third party image
Germ
10-04-2007 19:37:34
 Re: john in la in reply to john in la, 10-02-2007 20:23:46
Thanks for the info. Neat system.
john_bud
10-04-2007 12:36:16
I didn't know they could weigh a semi at 70!
Cool.
jb
john in la
10-04-2007 18:32:52
 Re: john in la in reply to john_bud, 10-04-2007 12:36:16
It works pretty good for dry vans or loads that do not move around but not very good with liquid loads that are very close to gross. The problem is a liquid load moves around and they will pull you in because you are over axle (to much weight to the front or rear) even know the computer does not have you as over gross.
This is where the pre pass does me some good. I can side step the motion scale by running the white line. The computer picks it up as the left wheel weighing more than the right wheel so it is a automatic pull in. BUT it does not register as a over weight condition because it only weighed 1/2 the truck. The left side. So the pre pass gives you a green light. Pre pass over rides the sign on the side of the road that tells you to pull in so you can bypass.
I may have to kill you now that I have filled you in on trade secrets.
john_bud
10-05-2007 09:02:14
 Re: john in la in reply to john in la, 10-04-2007 18:32:52
Using my best Sgt Shultz voice...
I know nothing! I see nothing!
john in la
10-05-2007 17:26:31
 Re: john in la in reply to john_bud, 10-05-2007 09:02:14
LOL
