Tractor Transporting Discussion Forum
How much will my truck pull
Jerry Eime
09-26-2007 20:01:05
I have a 2000 Chevy 3500 HD Flatbed dulley with the 454 motor and what is the base weight and how much will it pull. Thanks
jason, NW Ontario
09-27-2007 18:28:56
 Re: How much will my truck pull in reply to Jerry Eime, 09-26-2007 20:01:05
Curious - what kind of mileage do you get with your 454? We've got a '90 GM dually with the same engine: I get around 11 mpg empty, and between 8 and 9 when hauling.
Jason
Jerry Eime
10-02-2007 16:16:03
 Re: How much will my truck pull in reply to jason, NW Ontario, 09-27-2007 18:28:56
I"m not to sure what it gets when it not hauling a loaded trailer, because it never happens. lol But I am getting around 7-8 mpg. Is anyone having the problem of 454 motor being hard starting after it is hot. It only does it when its hot and I have to crank and Crank and finally it will start and puff out the most rich colud of smoke. I have been told to change the fule pressure reguator. I still need to do that. But I was just courios is it that happens to others.
gatorhide
09-27-2007 18:45:42
I've got a 97 Chevy K2500 5 sp. 4:10 axle 454 engine. Empty about 12, loaded 7 to 9 ?
RustyFarmall
09-27-2007 06:28:29
Your truck will weigh in at around 6,500# plus or minus. Your owners manual will tell you how much it can pull.
