Tractor Transporting Discussion Forum
Two Tractors on a 16' Tailer (possible or not)
Jerry Eime
09-26-2007 18:12:59
Is it possible to fit a 49 Allis Chalmers Wd narrow front and a 49 Farmall C narrow front onto a 16' car hauler trailer at the same time. The trailer is a dove tail and has no side rails. Thanks Just wondering.
Jerry Eime
09-26-2007 19:56:43
 Re: Two Tractors on a 16' Tailer (possible or not) in reply to Jerry Eime, 09-26-2007 18:12:59
Yes it is the typically trailer, with two 3500 lbs axles. I'm not freating my tough weight since I have a 3500 HD Flated Chevy with an industial two springs style hitch. I was just courios, since their is a show this weekend and I want to talk both of them. Thank now I know my limitations.
old
09-26-2007 19:15:44
Thats a yes no and maybe. I have hauled an Allis C and a JD-B on my 16 footer more then once. Doing that with a WD and a C might be pushing it a bit but if done right and you have the correct tires you can maybe get by with it but I wouldn't want to do it much or a long distance
Lumpy
09-26-2007 18:45:09
Depends on how much the two tractors weigh together. Is the car hauler the you typical trailer with 2- 3500 pound axels? If combined weight is over 6000 pounds, then I say no! One other thing... you would have to back 1 of them onto the trailer first!.... thats ALOT of tongue weight on your trailer hitch considering most are only rated for 500 pounds.
