Dave,On the lights, 3 possibilities come to mind. First, you may have a bad ground. A lot of light problems are caused by grounding problems. Check to see that the trailer has a ground wire, connected, and making good contact. There is also supposed to be a ground connection on the truck. Second, there may be an insulation problem on some of the wires in either the truck wireing going to the trailer connector or the same type of problem in the trailer wireing causing the current to cross over. Third, the trailer wireing may not be connected to the right pins in the 4 way plug. I don't know how to use the tester mentioned in the other post, but what I have done is to use a test light with probe and alligator clip. Turn lights on, put clip on truck bumper or frame, put probe in truck outlets until light comes on. Do same for brake lights and turn signals. This will tell you which pins on connector power which lights. Then, using probe and alligator clips, connect pin on truck to pin on trailer and see if corresponding lights work. Be aware that the light bulb in the trailer lights has a brighter filament for brakes and turn signals and a dimmer one for the lights. Be sure the turn signals are coming on bright and the tailights not so bright. Hope I haven't confused things, trailer lights are not my favorite thing to work on and I'm not good at it. KEH
