Tractor Transporting Discussion Forum
trailer pulling age
Craig Lysne in
09-21-2007 17:49:50
well i'll be getting my liscense soon and wanted to know how old i have to be before i could pull a trailer (maybe up to 9000#) Do i have to get a CDL first? anyone know?
any help would be greatly appreciated
Craig
Paul from MN
09-25-2007 13:03:00
 Re: trailer pulling age in reply to Craig Lysne in WI, 09-21-2007 17:49:50
Craig, you'd need to check with the state of Wisconsin. It may depend on your age. If you are getting your license at 16 many states have restrictions on what you can drive or pull. Ask your driving instructor.
caterpillar guy
09-25-2007 11:45:04
If you look at the tag in the door and it is less than the 26001 then no CDL now if you put a trailer on then check the GVWR of the trailer and the unit pulling it if the combined GVWR is the 26001 or over then yes CDL. Then log booksnot pads of paper with times on WILL NOT DUE must be in a "offical " log book" to be legal or some such time recording devise.
john in la
09-22-2007 04:33:12
You can drive any unit that has a gross weight rating of 26,000 lbs or less with your car licence. This weight would be a 1 ton with a trailer or less. Anything bigger than a 1 ton needs to be looked at in a case by case basies to see what the weight rating is.
If you want to drive anything bigger you would need a CDL and must be 18 to get it and it is limited to your state only.
To get a CDL that can be used to cross state lines you need to be 21.
