This may seem like the long answer; but let me try to give you all some situations (some may not apply to you) that may explain this better.When we are dealing with trailers the truck must carry a tag for the whole unit. In other words a tractor trailer unit has a 80,000 lb tag on the truck even though you need a trailer to carry this much weight. You say you have a Chevy 2500 but did not give any other info about the truck. If you look at the Link you will see gear ratio; engine size; ect play into weight ratings. So lets assume some things here. Your truck has a GVWR of 8600 lbs as you said. This is the truck only. You are legal to load anything in the bed of the truck till the truck grosses 8600 lbs. Now lets add a trailer..... .. It can pull a trailer that weighs 10,500 lbs and has a GCWR of 16,000 lbs. (This is a guess...Yours may be different) GCWR is the gross combined weight rating; truck; trailer; and load. Your trailer may be rated for more than the 10,500 lbs but that does not matter. They will use the truck weight ratings. In other words you could hook a semi trailer on your pick up and still only pull the truck ratings. You just shoot your self in the foot by doing this though. In the example your truck can pull a trailer and load that weighs 10,500 lbs. If you have a trailer that is rated and has axles to handle 25,000 lbs it is going to weigh more than one that is rated at 10,500 lbs so you lost load carrying ability. Just because your trailer is rated at 25,000 lbs does not mean you can load it this heavy; because the truck will not handle it. And if you think the DOT boys are bad; let the weight guys get after you. Or even worse get in a accident and let a lawyer find out you were pulling a trailer loaded more than the truck specs. With this example your truck should have a tag on it for 16,000 lbs if you plan on pulling a trailer. If it does not the DOT will use this 16,000 lbs any way because the truck is rated for it and can haul it. At 16,000 lbs you are well under the CDL laws so you will not need this; but you are over the 10,000 lb limit for DOT # rules. So now you need to find a exemption to not have the #. So the only question now is "Do you make money from the move" You do not have to answer yes to the question of... Do you haul for hire; the real question is... Do you make money from the move. Pulling the horse trailer to rides is exempt. That is for pleasure. If you sell the horse you could not deliver it because you are now making money. Most do not get this technical because how can they prove you are delivering the horse and not going to a pleasure ride. Going to pick up the F14 is exempt if you plan to restore and use it in shows. But if you were going to use it on the farm it is no longer exempt because the farm makes money. OR at least it is suppose to.... LOL. The fact that you do farming is what gets you in trouble because you now make money. Does not matter that you own all the equipment. You could fall under the farm exemption if you claim the farm as a income and fill out the proper paper work to get a farm tag for your truck. The farm exemption has teeth to it when trying to get around DOT laws. It will exempt anything up to a tractor trailer from some dot laws; even the CDL. The grass cutting is the real no no. This is not a farm so a farm tag and exemption does you no good and you are getting paid for the cutting of the grass so you must have the DOT # for that. So can you see the difference now. Take this test..... Does you truck have a GCWR of 10,000 lbs or more? Do you use the truck in a business. (farming is a business) If you can answer yes to both these questions you need a DOT #. If you answer NO to either question you do not need a DOT #. Hope this helps you out to understand the laws better.
