Tractor Transporting Discussion Forum
Re: You guys that haul regular, what’s your thoughts on thiis?
tony c.
02-07-2019 16:10:31
This is good advice about a heavier hitch.
#1 Upgrade the factory hitch to a Class V hitch, heaviest you can get.
#2 If you can, get a trailer rated 16,000 GVW with 8K axles and 17.5 tires, or see if you can upgrade the PJ.
#3 Definitely try to install a weight distributing hitch.
You will still be less than CDL weight since 3/4 ton truck is less than 10K, + a 16K trailer will be less than 26K total.
Since it seems you already own much of the "equipment" you may be stuck with using what you have to avoid expense. But I would definitely upgrade the receiver hitch to a heavy Class V (especially if rust if involved) and install a weight distributing hitch system. Also have good tires in excellent shape. I think you will be close to the limits of both truck and trailer but it may be a OK.
