Tractor Transporting Discussion Forum
Re: You guys that haul regular, what’s your thoughts on thiis?
d beatty
01-12-2019 01:58:17
You might want to look into a heavier hitch for truck. I pulled a 24ft. 14,000 lb. PJ deckover with K1500 GMC and put a 16,000 lb. Curt hitch under it. The Reese 14,000 that was under it looked cheap and wasn't bolted on with as heavy of hardware. Last spring I went to a Ford F 450 super duty to do all my tractor and heavy hauling.
tony c.
02-07-2019 16:10:31
 Re: You guys that haul regular, what’s your thoughts on thiis? in reply to d beatty, 01-12-2019 01:58:17
This is good advice about a heavier hitch.
#1 Upgrade the factory hitch to a Class V hitch, heaviest you can get.
#2 If you can, get a trailer rated 16,000 GVW with 8K axles and 17.5 tires, or see if you can upgrade the PJ.
#3 Definitely try to install a weight distributing hitch.
You will still be less than CDL weight since 3/4 ton truck is less than 10K, + a 16K trailer will be less than 26K total.
Since it seems you already own much of the "equipment" you may be stuck with using what you have to avoid expense. But I would definitely upgrade the receiver hitch to a heavy Class V (especially if rust if involved) and install a weight distributing hitch system. Also have good tires in excellent shape. I think you will be close to the limits of both truck and trailer but it may be a OK.
