Tractor Transporting Discussion Forum
Best way to set up my old 87 K2500 for gooseneck.
doug in illinoi
02-22-2008 15:55:07
Some of you are aware, some not, that my Mom's farmhouse burnt down last week. There was still a LOT of stuff left in it, seems meth heads decided to use the house as a lab and something blew. Anyhow, with the house gone I still have a LOT MORE stuff I need to get moved, my 2001 Chevy 4x4 2500 makes lousy MPG. Just a little less than 1000 mile round trip. At the 6 to 8 MPG the 01 makes, gets quite cashy. My old 87 Chevy has a healthy 6.2 diesel and tranny, the body is bad, the bed mounts are all junk. It made 17 or so empty, 11 or 12 when I brought the Ford 5000 diesel tractor here with it, in other words about twice the MPG as the 01. Has been setting a couple years, but not too worried about the mechanicals on it, had a crack in a steel fuel line when parked so would loose prime when it set. BUT, I am thinking as far as gooseneck puller, just put a flatbed on it. Or should I go the ugly route and just mount a gooseneck hitch frame direct and have enough channel iron work done to basically give me a platform to use 2 inch oak lumber, of which I have plenty, and build my own bed? I think a factory built flatbed would be better, but need ideas as to how to find one possibly used. When I start moving stuff, it will be every other weekend probably all spring and summer, I am going to build removable sideboards for my gooseneck flatbed dovetail, so I can load one vehicle and fill the rest of the load with stuff out of the buildings. Just a short list of needs moved, all need restored: 53 Cadillac, 51 Ford Tudor, 51 Chevy PU, 64 Ford Galaxy, 48 Willys PU and extra motor, trans and transfer case for it. Unsure about moving include 63 Impala, the thieves have found it, 65 GMC and 66 Chevy pickups, same reason. There are another 8 or 10 cars and a lot of farm equipment I just can't justify hauling this far, will take a week this spring and cut for scrap. But, getting off topic, is getting the 87 diesel gooseneck ready my best bet? Only big gripes with the 87 are dual glasspacks (LOUD) and it doesn't like to top some of the hills fully loaded on US136 in MO at more than about 35-40 MPH. Thanks, DOUG
glennster
02-25-2008 10:23:39
 Re: Best way to set up my old 87 K2500 for gooseneck. in reply to doug in illinois, 02-22-2008 15:55:07
doug, why not check in to having everything brought up on a low boy behind a semi. at 1000 mile round trip, take you 20 hours or so of driving, 350 dollars in fuel each trip, plus the wear tear and aggrivation of the hauling, may be cheaper that way, especially if you can find a truck deadheading back to illinos, they may make you a deal.
ericlb
02-23-2008 04:25:36
doug if you'll look at a few flatbeds, most will have the gooseneck ball already mounted in them, i put a tradewind brand on a 89 f350 and put extra mounts, from the flatbed to the truck frame just cause i felt better doing it, i never had a problem with it and hauled some very heavy loads the truck is still running around the county, for a new owner, my '83 chevy c30 has a midwest body [ 12 foot] on it but no gooseneck as its bedfloor is wood, i could make a door and mount one but with a 12 foot body the ball would bee too far back on the truck chassis in order to clear the trailer, so i didnt make it, i have a pickup with a regular factory body too, but a flatbed seems to work better and last longer for farm work, don;t just bolt a gooseneck hitch to your frame rails, the truck will be useless for anything but trailer towing and 1 gravel road and you wont have a rear window, or any paint on the rear of the cab
long hauler
02-22-2008 18:51:24
put a goose neck hitch in it. i sell the b&w turn over ball and have run it in all my trucks the last5 years and i like it a lot it only mounts to the frame and only a 4 inch hole in you bed and the 2 saftey hooks no rails. it can also be coverted to a 5 th wheel with the adapter in 2 minutes. check out WWW.TURNOVERBALL.COM i think this will help make the choice.
