Tractor Transporting Discussion Forum
dodge 4x4 frt. diff.
dieselpaul
02-21-2008 17:37:39
hello all-working on '97 dodge 3/4 ton 4x4. front diff has problems, making lots of noise [maybe tooth off] how can i easily disable unit for time being? r.h side is ok with disconnect kicked out but i gotta pull L.H. c.v. shaft assy or go into carrier to dsable. trying to figure easiest way. I just replaced engine turbo on cummins, guy is just trying to make drivable til he gathers more $$$- thanks for any help- paul
dieselpaul
02-22-2008 13:32:25
 Re: dodge 4x4 frt. diff. in reply to dieselpaul, 02-21-2008 17:37:39
follow-up on dodge 4x4 frt diff. pulled diff cover & found piece of metal in spider gear, making it knock. whole unit is in bad shape, but the only rotating parts are these gears, driven by l.h. axle shaft--when not using 4x4.-man, i still like those old hub lock-outs. but to answer my own question, looks like small diff gears could be pulled out to disable--easier than shaft,may be 50/50.
