Tractor Transporting Discussion Forum
Installing 5th wheel
D13
02-06-2008 07:48:16
I got a 5th wheel set up from a local auction. It has the plate on a crossbar, 2 large u-shaped hoops that go from the crossbar down to the bed, and 2 rails that would then go across the bed.
My question is, how does this install to the bed?It doesn't seem like bolting the rais to the bed, not the frame, would be a good idea. I can't imagine it supporting the weight even if I bolted it thru the bed support crossrails.
Should there be supports across the bed underneath, then drill and bolt? Do the rails goe under the bed and then drill holes for the hoop legs to go thru? If it should have support, what size? 2x2 box bolted to the frame?
Also, should it be centered over the axle, or slightly forward?
Peavt Tx
02-06-2008 11:11:28
 Re: Installing 5th wheel in reply to D13, 02-06-2008 07:48:16
D13
The rails go inside the bed. You should have 4 pieces that look like angle iron about 3 inches long. They go under the bed. The mounting bolts go thru the rails,thru the bed and thru the angle pieces. The angles then bolt or weld to the truck frame.The papers that came with the fith wheel new gave measurements to mount in the different brand trucks. I assume you don't have the papers but I think you can get them online if you know the brand and model of your fith wheel. If it happens to be a Reese 15K and inatalling in a F350, let me know and I will get measurements from my truck.
Peavy
D13
02-07-2008 04:47:35
 Re: Installing 5th wheel in reply to Peavt Tx, 02-06-2008 11:11:28
Mine's destined for my 99 Silverado or my 82 GMC 2500 but now I see what I need, I'll either find or fab a brace. Many thanks for the help.
