Cub pressure plate release leaver adjustment?????
GERRY
08-02-1998 06:30:01
Can anyone helpl with info. on a simple adjustment procedure to set release levers on cub rockford clutch or have info on the service tool FES 50 which is used to set up the pressure plaate. Thanks GERRY
Rick B.
08-03-1998 15:49:16
 Re: Cub pressure plate release leaver adjustment????? in reply to GERRY, 08-02-1998 06:30:01
: Can anyone helpl with info. on a simple : adjustment procedure to set release levers : on cub rockford clutch or have info on the : service tool FES 50 which is used to set : up the pressure plaate. Thanks GERRY
> I guess no one has the info you are looking for, and you don't have access to a CaseIH dealer with the proper tools, so I will try to help. This proceedure will work on any single disc clutch if you are desperate enough. With tractor split, disc & pressure plate ass'y bolted to flywheel; 1: Adjust release bearing to about 7/8 of the way forward using all normal external adjustment(s). Install any return springs. 2: using a straightedge(s) & square and being as accurate as possible, measure depth from the front mounting surface of the bellhousing to the thrust surface of the release bearing. 3: Using similar tools, measure from contact areas on fingers to the mount face on rear of engine. 4: Adjust finger height to match or 1/8" less than dimension found in 2. Check clutch for freeplay & disengagement as soon as the two halves are bolted up tight, in case further adjustment is needed. Be VERY careful to have all 3 fingers adjusted to EXACTLY the same height. Good luck.
