: : : No it would break if used on a part that is stressed(i.e.bearing,PTO shaft,etc) As for cleaning parts...dunk it in a bit of gasoline and swirl it around. (yeah,you get people who tell you its too dangerous,its not a good idea,etc Anyhow,it does work,i succesfully cleaned an oil pump like that. Put it in the handy (half full) 5 gallon bucket of waste gasoline that sits OUTSIDE the side door. Turned the drive shaft a bit to flush the gear teeth out then took it apart. (I dont mind getting dirty and greasy etc,but some ladies do,no im not a girl either,I took washed it so that when I took it apart on the workbench it would not get oil all over because then if my mom saw it she would say it would creep along the floor and get on her car which is on the other side of the garage. The tractor tent is too sandy to work on the engine so we did it in the garage which is where the tractor stays anyway. And I did not find one trace of oil in that pump after washing it. Use gasoline,dont smoke,keep the gas barrel outside and put a lid on it...itll be fine. Good Luck! (Im not responsible for any injuries caused by gas buckets exploding or anything related to that.) : : Risk of blowing up aside, if I was going to epoxy something I would use the brake clean, the good chlorinated stuff, I like J-B brand the best. I think even gas will leave a slight film, but the brake clean cuts the oil, evaporates fast and leaves NO oil film. My 2 cents worth. : Thanks guys. Let us know how it turns out.
