Briggs stratton datton generators
Sheldon
03-03-2000 19:16:49
I have broken rings. Cannot figure out how to remove the generator from the engine. Any help anyone has would be greatly appreciated.
mike werner
03-04-2000 10:36:40
 Re: briggs stratton datton generators in reply to Sheldon, 03-03-2000 19:16:49
Sheldon,
Depending on the brand,there is a long bolt that goes through the rotor,into the crankshaft.The crankshaft is probably tapered,so it may be a pill to seperate.Unscrew the bolt all the way out.
Screw bolt in,then back out a couple of turns.
Rap end of bolt with soft hammer, this will generally unseat the taper.I have done this on many a generator with no problems. Good luck.
