Oxy-propane rig
Charlie
03-02-2000 19:51:01
I am about to get my oxygen tank to go with a torch that was given to me. I am rusty on acetelyne rigs an have never used a propane one. What pressures should I use on both gasses? Same pressure for cutting and brazing? And any advice from the experts out there would be appreciated.
Thanks Charlie
Tom S.
03-06-2000 06:32:50
 Re: Oxy-propane rig in reply to Charlie, 03-02-2000 19:51:01
What ever you do, don't let anybody here know if you lay one of the cylinders down on it's side ! ! Tom S.
FRED
03-03-2000 18:37:28
In my shop I use only propane on #1 or #2 tip cutting try 35-40 psi. ox.3-5 psi fuel. Brazing try 5psi ox. 2psi fuel good luck FRED PS turn on just a little ox when lighting the torch. it helps. FRED
