Auto repair board
Tim(ny)
02-22-2000 08:17:56
Does anybody know of a good auto repair message board? I have a Buick with ABS problems, and I can't find anything.
bobby
07-17-2001 20:52:11
 Re: Auto repair board in reply to Tim(ny), 02-22-2000 08:17:56
does anyone know torque specs for the cyl heads of a 98 ford taurus 3.0L 12V
Dave
07-10-2001 19:04:31
try this one...
Tim(ny)
02-24-2000 05:35:16
Thanks for all the info, guys. All the signs point to a bad torque converter lockup solenoid. Its in the shop today.
big jake
02-23-2000 09:49:44
heres a few more that might help
Link
Link
Link
Link
http://www.aircondition.com/>Link
clooney
02-22-2000 15:47:16
Tim, whats the problem with your ABS? & what year & model is it.
Tim(ny)
02-23-2000 05:29:02
 Re: Re: Auto repair board in reply to clooney, 02-22-2000 15:47:16
Its a 92 Skylark, and I thought it was ABS because it would grab and lock up on stopping. But now I'm leaning toward trans, because yesterday it did it just slowing down going uphill to a stop sign without touching the brake at all. Also, it doesn't do it if you downshift the AT manually before braking. So I'm going to go talk to the trans man today. Sure feels like a brake lockup though.
will
02-23-2000 19:01:17
 Re: Re: Re: Auto repair board in reply to Tim(ny), 02-23-2000 05:29:02
Sounds like the sensor in the tranny that tells the clutch to disengage when slowing down. Had one replaced last year on similar GM car. About $200 at the tranny shop. Watch out. Some tranny people will tell you that the tranny needs to be rebuilt. Good luck
clooney
02-23-2000 17:09:36
Tim, if it was an ABS problem you would feel the brake pedal pulsing & get hard, or the ABS light would be on. It could be a brake problem though. If you feel it again, kick the trans shift lever into neutral while its doing it, if the problem goes away it probably is a trans problem, if it is stiil there it still could be a trans problem or it could be the brakes locking up. Post back if you can determine which system it is and I will talk you through some basic tests.
Tom R
02-22-2000 09:53:43
Tim:
I will try to give you a link to one that is fair for problems on general type of things.
Here is the URL incase the Link fails.
Link
Tom S.
02-23-2000 06:39:01
 Re: Re: Auto repair board in reply to Tom R, 02-22-2000 09:53:43
Tom R., you are a champion and a scholar! I have been looking for a site like this forever. Do you know of a large truck site like this?
Thanx greatly. Tom S.
Tim(ny)
02-22-2000 10:55:40
Thanks, Tom, I posted my problem on that board.
