Paint sprayer won't spray
john
02-14-2000 10:28:41
Bought a new Craftsman paint sprayer(air compressor type) to paint some lattice. Old sprayer not cleaned properly and thought this would be the solution. Not a high priced unit- but good enough.
Anyway inspite of following instructions, unit would not pick up and spray full-bodied(water based primer) paint . What gives? Any ideas?
Thanks.
bo
02-15-2000 18:55:14
 Re: paint sprayer won't spray in reply to john , 02-14-2000 10:28:41
don't know what you mean by "compressor" type, if you are using an air compressor to power the spray gun then it won't spray latex. You need a airless sprayer like the wagner types. They use a pump to pick up paint and not air pressure. bo
clooney
02-14-2000 16:16:53
John, probably need to thin the paint more. If it is a pressure-siphon type of gun, turn the screw to the pressure position, you might want to try it without the strainer on the end of the pickup and a little more air pressure also. You might see if sears offers a head kit to spray thicker paint.
