OLIVER 550 GAS FARM TRACTOR-SPLIT
Tom
07-24-1998 21:51:40
PTO failed and have to split tractor to fix. With current hoist setup I have 3 feet to roll front motor away from rear section.I have manual but it does not state if this will be enough room to get into the clutch.
While I am in there I will replace the drive clutch also. Any advise? THANKS
Rick B.
07-26-1998 14:33:05
 Re: OLIVER 550 GAS FARM TRACTOR-SPLIT in reply to Tom, 07-24-1998 21:51:40
: PTO failed and have to split tractor to fix. With current hoist setup I have 3 feet to roll front motor away : from rear section.I have manual but it does not state if this will be enough room to get into the clutch.
: While I am in there I will replace the drive clutch also. Any advise? THANKS
Here's a dumb question: Isn't the pto clutch on the 550 accessed by making the REAR split, not the front split at the front of the bellhousing??
Tom
07-26-1998 19:59:25
 Re: Re: OLIVER 550 GAS FARM TRACTOR-SPLIT in reply to Rick B., 07-26-1998 14:33:05
: : PTO failed and have to split tractor to fix. With current hoist setup I have 3 feet to roll front motor away : : from rear section.I have manual but it does not state if this will be enough room to get into the clutch.
: : While I am in there I will replace the drive clutch also. Any advise? THANKS
: Here's a dumb question: Isn't the pto clutch on the 550 accessed by making the REAR split, not the front split at the front of the bellhousing??
Not on this tractor. The inspection plate to adjust the PTO clutch,Driver\Drivin plates that make up this unit is just behind the motor and
on bottom of tractor. I noticed the PTO clutch stopped working and when I pulled this inspection plate the parts to the
PTO clutch fell out into my hand. Not a good sign. Book states must split tractor to get into this. Thanks
Sam Rule
07-25-1998 20:51:02
I have seen this recently at the John Deere shop where I work, although it was on a JD 850.
I don't know how much different it will be for your Oliver. 3 ft just might be enough the problem you will have with a short space is the long PTO shaft it might come apart with that much space.
As for advice, just unhook all fuel lines, steering linkages, etc. and then hoist the back part and put a wheel jack under the front part and split
Tom
07-26-1998 20:32:23
 Re: Re: OLIVER 550 GAS FARM TRACTOR-SPLIT in reply to Sam Rule, 07-25-1998 20:51:02
: I have seen this recently at the John Deere shop where I work, although it was on a JD 850.
: I don't know how much different it will be for your Oliver. 3 ft just might be enough the problem you will have with a short space is the long PTO shaft it might come apart with that much space.
: As for advice, just unhook all fuel lines, steering linkages, etc. and then hoist the back part and put a wheel jack under the front part and split
Thanks for the advice. Will let you know how it goes.
Sam
07-25-1998 20:55:14
Also, replace all clutch disks, through out bearings and resurface the flywheel and other surfaces.
THese things have to be done eventualy anyways, so might as well do them while it is open. THey had to split the tractor twice where I work because they did not do these things.
