Bbott-heres your saw...
Fred Martin
02-08-2000 12:52:45
its on ebay, 14" cold saw. 700+ lbs. Its in Chicago. Bid now is $200. Ends Feb.12 Item #255658375
Fred
bbott thanks Fred...
02-08-2000 16:47:21
 Re: bbott-heres your saw... in reply to Fred Martin, 02-08-2000 12:52:45
Thanks a bunch... I've never bought on eBay but there's always a first time...
The Doringer cold saws are up 4K +
The ELLIS band saws are about $2500
The Cheapest American Made 7x12 Bandsaw is $1100
Chinese stuff is around $800..
Haven't looked at any Chinese cold saws for
comparison pricing yet.. will have to do so and
compare to what's on eBay to know what it's worth.
Maybe I'll see what happens with eBay. The cold saw would take up lots less room in the shop and be just fine for 99pct of what I need to do !
Thanks again.
bbott
Shucks... It was 3 phase...
02-11-2000 12:26:22
 Re: Re: bbott-heres your saw... in reply to bbott thanks Fred..., 02-08-2000 16:47:21
Could have probably replaced the
motor but... being as I'm short on time
as well as money it would have turned
into another project !
bbott
Fred Martin
02-13-2000 13:08:55
 Re: Re: Re: bbott-heres your saw... in reply to Shucks... It was 3 phase..., 02-11-2000 12:26:22
bbot-You git 'er if the price is right and me or someone else will show you how to run it on single phase. It ain't too hard or expensive. Trust me.
Terry
02-15-2000 07:23:32
 Re: Re: Re: Re: bbott-heres your saw... in reply to Fred Martin, 02-13-2000 13:08:55
Fred, I have seen a setup to run a 3 phase motor on single phase. Made up of old capacitors and relays and such out of a scrap yard. Is there a simple way to figure out what size capacitors and everything to use. I have told several people about this setup including some electricians and most don't believe it can be done but I have watched one work. Terry
David Rice
02-20-2000 06:46:35
 Re: Re: Re: Re: Re: bbott-heres your saw... in reply to Terry, 02-15-2000 07:23:32
Terry,
If you get no answer you might try at
http://www.chaski.com/wwwboard/machine/index.html
