Clutch
mel
02-07-2000 09:48:13
I need a little help here. I have a rockford clutch on a super c farmall. The repair manual says that the measurement for the levers is 2 3/8 inches. If I lay the pressure plate face down on the bench and measure from the bench to the tips of the levers I get exactly 3 inches. Am I doing this right ??? The old clutch disk was not worn down to the rivets but I am replacing the throw-out bearing and the disk because the tractor is split. Any advise would be appreciated. Tnx
RickB.
02-07-2000 15:31:57
 Re: clutch in reply to mel, 02-07-2000 09:48:13
Measure from the friction surface on the FLYWHEEL to the fingers with the disc & press. plate assembled on the flywheel.
