Frost in air compressor
Mike
02-02-2000 09:07:34
couple weeks ago I posted about service truck compressor frosting up. I tried several suggestions posted but none solved the problem; although some helped somewhat. This morning I took apart my quick connect and removed the inside baffle. No more frost upp problems and all you do is change attachments quickly and carefully. Also I lowered my opperating pressure from 190 to 115 psi. This after pressure shut down froze and charged the tank to up around 240 psi before overload blew. That could have been exciting. Mike
clooney
02-02-2000 16:12:39
 Re: frost in air compressor in reply to Mike, 02-02-2000 09:07:34
Mike, good follow-up post --thank you
