Clean tank
vince
02-01-2000 21:28:19
one of my jacobsen was out two winters. the one and hafe gal tank is in bad shape inside. i need to have it repaired. who fixs tanks thanks [email protected]
clooney
02-03-2000 13:32:54
 Re: clean tank in reply to vince, 02-01-2000 21:28:19
Vince, try this web site. If you put "fuel tank repair" in one of your search engines you might find one closer to you.
chuck
02-02-2000 20:55:46
Muriatic acid dissolves rust. it's cheap, put some in and slosh around , rinse out with water. JB Weld seals rusted through areas, roughen the spot, sand down to bare metal, spread the stuff on clean, dry surface. Set the tank with the glue up, it runs, wait 24+ hours. Install a good large fuel filter. Get a spare filter.
