Filling wet tires.
Chip S.
02-01-2000 06:48:57
Can anyone point me toward how to fill tires with anti-freeze? Or changing back tires in general?. My dealer wants $175 to do the job. Sounds like a lot.
ted
02-16-2000 11:16:56
 Re: Filling wet tires. in reply to Chip S., 02-01-2000 06:48:57
I would put tubes in them and fill with Calicum mix. Much cheaper than antifreeze. The tubes should help save the rims. Anyways, Ca is a lot heavier than antifreeze and water.
You can change the tires yourself if you can get the bead broke. And with a tube you don't have to fight setting the bead when filling.
Jim
02-02-2000 03:42:24
Go to Norther Hydraulics, they have a liquid transfer pump thats elec and cheap. Put your mix in a barrel and pump it in thru the special fixture you will have to buy at a tire shop or dealer.
MikeH(Tx)
02-01-2000 15:23:49
Tyler may have the best answer, but if you want to do it yourself, buy the filler attachment from your tractor dealer (any tractor dealer). It connects a tire's Schraeder valve to the male end of a garden hose. Then you also need a short piece of garden hose with the male end, and a funnel. The hose piece and funnel are used to pour in the antifreeze. Then connect a garden hose and fill to 75% full. Set fill level by where you have the valve positioned on the parked tractor. Fill until water starts to runs out the valve when you let the air out.
This takes a BUNCH of antifreeze though. I used a 1:4 mix and still put about 10 gallons of antifreeze in each 24in tire, even though it's warm here in Central Tx. Calculate what you need from finding the volume of your tire and use the back of the antifreeze jug to calculate the ratio you need for your min temp.
math example:
Volume of a torus is V=2 times pi-squared times R times r-squared. (R is distance between tire crossection centers, r is radius of tire crossection). For 24in wheels, this works out to 10 cu ft (about). Times 7.5 gal/cu-ft is 75 gallons. Fill to 75% and you have 56gal. 10 gal of antifreeze and 40 gal of water make a 1:4 mix.
Or about $40 per tire doing it yourself. If you live where winters are real, you probably need to use a 1:2 or 1:1 mix making the $175 figure start to look pretty fair.
Lastly (on a very long post, sorry) is to be really careful around cats and dogs. Antifreeze tastes good to them and will kill them quickly.
Tyler(WA)
02-01-2000 08:33:42
If you have a Les Schwab tire dealer in your area, call them. I pay $100 for a complete wet tire drain/refill and a new tube. I would stick to CaCl instead of antifreeze. It's cheaper, heavier and does well if you paint the rims and keep good bladdres.
Mike
02-02-2000 08:59:10
 Re: Re: Filling wet tires. in reply to Tyler(WA), 02-01-2000 08:33:42
I just came in to warm up my feet for lunch. I changed 2 tires this morning. Charged one guy 100$ to put a new tube in an 18.4 34 and one fella 65 bucks to patch tube in a 20.8 38. So depending on what size tire you are doing 175 is to much. I charge 35$ an hour plus materials and I am the cheapest show in town(in northeast NY anyways) Mike
Mickey
02-03-2000 05:59:12
 Re: Re: Re: Filling wet tires. in reply to Mike, 02-02-2000 08:59:10
Mike ,i also change all kinds of tire's' have been self employed for 15years,have been selling and servicing tire's for 30 year's, Mickey
