Briggs & Stratton Motor
Kenny Guy
07-15-1998 10:45:36
I have a hot water pressure washer and it has an 18hp Briggs & Stratton horizonal motor. The problem is that the block is busted and I am in dire need of either a replacement block or another motor. If anyone can be of any assistance, please email me.... thanks
Gil Warren
08-03-1998 17:29:19
 Re: Briggs & Stratton Motor in reply to Kenny Guy, 07-15-1998 10:45:36
It has been my experience that unless you are really good at small
engine repair it is cheaper in the long run to buy a new motor and be done with it.
John Fritz
07-20-1998 07:24:28
: I have a hot water pressure washer and it has an 18hp Briggs & Stratton horizonal motor. The problem is that the block is busted and I am in dire need of either a replacement block or another motor. If anyone can be of any assistance, please email me.... thanks
Kenny, get ahold of a Northern Hydraulics catalog. They specialize in one lungers and have a large variety. I would stick with a Kohler, Tecunseh or even an Onan if you can afford it. Stay away from Briggs.
kevin
08-01-1999 15:39:04
 Re: Re: Briggs Stratton Motor in reply to John Fritz, 07-20-1998 07:24:28
: : : I have a hot water pressure washer and it has an 18hp Briggs & Stratton horizonal motor. The problem is that the block is busted and I am in dire need of either a replacement block or another motor. If anyone can be of any assistance, please email me.... thanks
: Kenny, get ahold of a Northern Hydraulics catalog. They specialize in one lungers and have a large variety. I would stick with a Kohler, Tecunseh or even an Onan if you can afford it. Stay away from Briggs.
How do you set the timing on a 12 hp. Ind Briggs
Kevin Fry
08-01-1999 15:45:42
 Re: Re: Re: Briggs Stratton Motor in reply to kevin , 08-01-1999 15:39:04
Do any of you dumb asses know how to set the timing on a 12 horse power Ind. Briggs?????
