Hydraulic Chainsaw Mill
Kim Hartshorn
01-20-2000 07:53:05
I am in the process of searching through parts bins and used stuff to accumulate the various pieces for a shop project hydraulic chainsaw mill.
I found a pump that was used on a homemade pto splitter, it has 1" ports so I think it should do pretty good but I still need to clean it up and see if I can find any actual information on it.
The question for the day is that I am planning on running this contraption with my 17hp (pto) tractor. Gas powered chainsaw mills use saws of about 4ci/7hp so intuitively it seems like the tractor should be big enough for what I want to do..still I am a little worried. In my journeys I have acquired a 3' cast iron balanced flywheel that came off of some sort of flat belt contraption and I am wondering if it would make life easier on the tractor if I put this in line with the pto shaft to the pump? Or will the drag on the tractor actually be easier if I just listen to the saw and ease up on the feed when it bogs down?
Thanks
Kim
