Engine and hydraulic oil
Floyd
07-03-1998 20:50:19
I recently purchased an old TO-30 Ferguson tractor
a 1953, and was wondering what kind of engine oil
to put in it, I am assuming 30 wt. oil, and also what kind of hydraulic oil or
transmition oil to put in it. Also where is the
place to put the hydaulic oil in, we can not find it. Thanks
John Burnett
07-10-1998 01:04:18
 Re: engine and hydraulic oil in reply to Floyd, 07-03-1998 20:50:19
My 1964 John Deere Operator's manual suggests using a 10w-30 in both the engine, transmission (uses the same oil for hydraulic functions) and PTO. As an alternative, it says you may use Hydraulic Oil in the transmission. I would suspect you could use either one in your MF tranny. John
: I recently purchased an old TO-30 Ferguson tractor
: a 1953, and was wondering what kind of engine oil
: to put in it, I am assuming 30 wt. oil, and also what kind of hydraulic oil or
: transmition oil to put in it. Also where is the
: place to put the hydaulic oil in, we can not find it. Thanks
Ted
07-05-1998 07:33:58
Floyd, 30 or 10w-30 oil will be Ok in the engine.
In the transmission, you need to use hytrans because the hydraulics use the oil in the transmision as it's working fluid (which is why you can't find a place to put the hydraulic oil).
Good Luck,
Ted
yasuhiro okina
11-09-1998 22:15:24
 Re: Re: engine and hydraulic oil in reply to Ted, 07-05-1998 07:33:58
: : I have a customer who had purchased 1 unit electronic folklift: sugico model: sri-20-2-33 but he does not know what kind of hydraulic oil should be used in the up down folklift hydraulic system, while the spare parts manual indicates that sae10 should be used.
is it only concerned with viscosity, single
grade 10 ?
Thanks and regards
