Autoparts hydraulic projects
Dave
01-14-2000 10:09:55
Do you know of any good websites on making some projects from recycling auto parts?
I have a couple of small hydraulic projects in mind that someday I would like to realize. I would like to use autoparts for these for example power steering pump for a hydraulic pump. This may be slow but maybe I can live with it or try something else. Some projects are a woodsplitter, press, and lifts.
kim hartshorn
01-17-2000 10:48:29
 Re: autoparts hydraulic projects in reply to Dave, 01-14-2000 10:09:55
I have been told that gear pumps can be driven as motors. Would this work with a ps pump?
Just Wondering
Kim
Actually I am wondering if there is a hydraulic motor that runs at around 8k rpm at nominal gpm. It would be for a hydraulic chain saw blade
Miles
01-14-2000 17:14:11
I have an a/c compressor for my air compressor. Slow but works.
Tom S.
01-15-2000 06:44:12
 Re: Re: autoparts hydraulic projects in reply to Miles , 01-14-2000 17:14:11
I have seen this done before. How do you oil the compressor? Tom S.
Burrhead
01-15-2000 11:58:00
 Re: Re: Re: autoparts hydraulic projects in reply to Tom S., 01-15-2000 06:44:12
Put just a squirt from can in the intake of the compressor every time you use it and it works fine. This compressor has lasted 2 yrs and still going here.
clooney
01-14-2000 14:16:16
Dave, most P/S pumps have a "FLOW CONTROL" valve in them to keep the flow constant due to the varying speeds they run at in auto application. I am most familar with G.M. But they all have to have some type of flow control. The valve by-passes some of the oil back to the reservoir to maintain a constant flow. If you remove the valve it will by-pass all the oil back to the reservoir. Auto P/S pumps also are not made to work at a constant high load. A two stage pump works best for log splitters.
Tyler(WA)
01-14-2000 12:54:58
A P/S pump would make a mighty slow log splitter. They're designed for about a 1.5" cylinder. It would push a 3" cylinder awfully slow.
Maybe you could gang two or three together though.
Jonathan
01-14-2000 17:26:56
 Re: Re: autoparts hydraulic projects in reply to Tyler(WA), 01-14-2000 12:54:58
....or you could use an actual hydraulic pump that is suited for such a task and save yourself alot of aggrevation....just an idea !!
Dave
01-14-2000 13:27:17
Would a 3" cylinder be necessary for a wood splitter?
