Walbro carbs...
Eric
01-13-2000 16:42:33
I took the motor out of my Remington chainsaw, and am planning on mounting on a bike, for power assist. It has a walbro carb, which has two line hook-ups. a white one, and a black one. On of the tubes puts pressure into the gas tank, and the other recieves gas. Can someone tell me which is which?
NEV COOPER (Station Radio Call Sign - G3LMO)
02-14-2001 10:02:29
 Re: Walbro carbs... in reply to Eric, 01-13-2000 16:42:33
WALBRO (MDC-15) CARB
Can anyone with personal knowledge help with set-up, and spares availability for this Carb please.
It will fire, and run for approx 5 to 10 secs if raw fuel mixture is first applied to the carb intake.
I therefore suspect prop with the fuel pump section, and/or the fuel metering section.
However, I have replaced the pump diaphram, and the metering diaphram, plus the two gasket.
What is behind the 7/16" Welsh Plug??? Could that be the problem area.
Original problem was the carb had not been used for approx 12 years :-) :-)
Have also replace the metering spring with a new item.
Have not taken out the 7/16" Welsh Plug YET.....As I do not seem to be able to get one to replace it.
Any help.....Manual....etc....Greatly appreciated.
Nev Cooper
"Ramwood"
St Mawgan
Cornwall
TR8 4EY
UK
Kraig langley jr
02-10-2001 17:57:25
Dear Walbro carbs I need new parts for my 74 articat because im trying to restore it but the snowmodile diller wants to charge me around 300 dollors because thay wont sell me it seprtley. Which I dont have so I was wondering if i could get these parts from you for a way cheaper price.the parts i need for the carb are the shaft assemblt - throttle,needle assembly -poweraso a idle assembly the carbs numder is 0170-023or it could be WDA31so please write back or give me some information adout where i can ge these parts. Kraig langley p.s. i only have 45 dollars to spend.
tony marconi
10-08-2000 17:24:30
I have just been given a woodsplitter with a tecumseh motor on it. I'm pretty sure it has a Walbro carb. on it because it looks just like the one on my Sears rototiller and it is a Walbro for sure. I did see a number on a flat spot that read #773. Like I said I just got it today and for the life of me I can't get this thing regulated. I think I screwed that needle valve in the bowl just about every position imaginable and it still won't run. Where do you think I should start? Maybe a new carb?.... Thanx, Tony
Fred Martin
01-16-2000 09:12:15
Hi Eric from Fred It runs in my mind that the inlet side has a filter in it and the other side has a diaphram for pushing the fuel. If you took one side off, you would be clued by looking. Bare in mind that I don't think I've taken this particular carburator apart but logic tells me this. Doesn't scavenging of the cylinder work the diaphram? Another way is to trace the plastic fuel lines. Fred from the Mung Factory
Larry Barnhill
02-02-2001 17:04:40
 Re: Re: Walbro carbs... in reply to Fred Martin, 01-16-2000 09:12:15
Looking for a place to order a diaphragm for walbro carb. Any suggestions?
salonen andy
01-24-2001 16:39:18
I have WF1B carb on a snowmobile where can I get exploded view of same
