Power washer/sandblaster
Sam Mills
06-28-1998 10:04:38
Have a 5.5HP, 3000PSI power washer that works fine for cleaning old Ford 671, decks, and driveway concrete. Thinking of buying a sandblaster attachment to give old Ford a new paint job this winter. Appreciate comments on how effective the sandblast areas might take primer/paint?
Dan
06-30-1998 19:19:57
 Re: Power washer/sandblaster in reply to Sam Mills, 06-28-1998 10:04:38
You are kidding, right? }:-) Depending upon what sort of blast media you use, of course, a sandblasted surface provides one heck of a surface for paint. The choice of media is the primary thing; when I first recieved my sandblaster (pressure-type) I couldn't wait to try it out so I sifted some of the kids play sand to use- oh man did it do the trick on old paint and rust. I blasted one of the running board supports from my '53 Ford tractor (it was handy) and the blasting process left it looking better than new.
Again, choice of blast media is paramount. Fine graded sand leaves a clean, matte surface that is... somewhat rough to the touch. Rough is too harsh a word, here, lets just say you can feel the texture rather than see it. Does this make sense? A primer/surfacer may be necessary when using graded sand as a blast media.
Blast media such as glass beads leaves a satin-smooth surface. Different media are designed for different applications, of course. Graded sand is not a great choice for thin sheet metal due to heat build up; crushed walnut shells or plastic media is designed for this sort of application. There are also silicon carbide and aluminum oxide abrasives. These are very aggressive medias.
It all gets confusing, so I will suggest going to the experts- TIP Tools and Equipment @www.tiptools.com. I will include a link, below. TIP will send you a free catalog that will answer most of your questions about blast media/pressure blasting.
SAFETY- if I understand correctly, you will be using a wet-blast technique? This, I assume, will virtually eliminate dust? Blast media dust is WAY bad, man. Glass bead dust is not for breathing. The dust from using graded sand is almost as bad, believe it or not. Silicosis, a fibrotic respiratory disease caused from inhalation of silica, is no joke. Intense exposure to silica may result in disease in a year or less.
Dan (more)
06-30-1998 20:07:46
 Re: Re: Power washer/sandblaster in reply to Dan, 06-30-1998 19:19:57
A passing thought- with a 5.5HP 3000psi power washer, you may not even need additional blast media? I prepped. primed and painted my center housing several months ago then recently decided to clean out 45 years of crud by taking the housing to the local car wash. The car wash did a decent job of blasting out the oil sludge, and it did a great job of removing not only the new paint, but most of the primer, too.
No big deal, it was the wrong color anyway.
Lots of folks do not use a sandblaster in restorations, by the way. In addition to the hazard of silicon dust, there is the real hazard of lead-based paint dust from those old paint formulations. You really do not want that stuff in the same yard your kids play in, much less your lungs or theirs (many thanks to John.COLO for bringing this aspect to our collective attention).
Mike
07-01-1998 14:32:33
 Re: Re: Re: Power washer/sandblaster in reply to Dan (more), 06-30-1998 20:07:46
: A passing thought- with a 5.5HP 3000psi power washer, you may not even need additional blast media? I prepped. primed and painted my center housing several months ago then recently decided to clean out 45 years of crud by taking the housing to the local car wash. The car wash did a decent job of blasting out the oil sludge, and it did a great job of removing not only the new paint, but most of the primer, too.
: No big deal, it was the wrong color anyway.
: Lots of folks do not use a sandblaster in restorations, by the way. In addition to the hazard of silicon dust, there is the real hazard of lead-based paint dust from those old paint formulations. You really do not want that stuff in the same yard your kids play in, much less your lungs or theirs (many thanks to John.COLO for bringing this aspect to our collective attention).
The wet blast can also leave particulate matter ("small chunks" for people like me) that can become airborne when it dries out. You don't want that around your kids or yourself either.
And depending how tight the regulations are where you live, you might have a problem getting rid of the blast dust/sludge because of the "good stuff" in it (sand/glass dust, lead, cadmium, zinc and others).
