Ferurson TO30 Timing Problems
John Rose
06-28-1998 03:00:53
The cam timing gear recently broke on my Ferguson TO 30 Z-129 Cont. engine. I ordered a new gear and properly aligned the timing marks on the new gear with the crank gear. When I checked the valve timing, the intake valve on No. 1 was wide open at top dead center. Any help on how far to move the camgear?
Ted
07-05-1998 07:44:09
 Re: Ferurson TO30 Timing Problems in reply to John Rose, 06-28-1998 03:00:53
: The cam timing gear recently broke on my Ferguson TO 30 Z-129 Cont. engine. I ordered a new gear and properly aligned the timing marks on the new gear with the crank gear. When I checked the valve timing, the intake valve on No. 1 was wide open at top dead center. Any help on how far to move the camgear?
John, don't change anything. If the timing marks are lined up properly, then the marks are set up on the opposite cylinder than #1. (Example #4 on a 4cyl. engine with a 1,3,4,2 firing order.) In which case, #1 would be on the intake stroke. Why they do this is beyond me, but I have seen many different engines that are set up that way.
Good Luck, Ted.
Cliff
11-01-1998 12:55:46
 Re: Re: Ferurson TO30 Timing Problems in reply to Ted, 07-05-1998 07:44:09
: : The cam timing gear recently broke on my Ferguson TO 30 Z-129 Cont. engine. I ordered a new gear and properly aligned the timing marks on the new gear with the crank gear. When I checked the valve timing, the intake valve on No. 1 was wide open at top dead center. Any help on how far to move the camgear?
: : John, don't change anything. If the timing marks are lined up properly, then the marks are set up on the opposite cylinder than #1. (Example #4 on a 4cyl. engine with a 1,3,4,2 firing order.) In which case, #1 would be on the intake stroke. Why they do this is beyond me, but I have seen many different engines that are set up that way.
: Good Luck, Ted.
Thought my timing was off aslo because of all the backfiring Turns out that the dern thing has no compression and is fouling the plugs real quick. Runs like a spotted ass ape til that happens
