Concerning Welding
Barney R.
01-06-2000 17:25:33
I am interested in learning how to weld. Could somebody please point me in the right direction on where I can sign up for a welding class? Or is there a better way to learn?
What is best to learn? Mig, Tig, Arc, Wirefeed, Stick? And could somebody please explain the diffrences?
Regards... Barney R. (Who knows nothing about welding!)
mike
01-07-2000 09:34:52
 Re: Concerning Welding in reply to Barney R., 01-06-2000 17:25:33
It depends on what you want to do. If you are working in a shop, wire feed migs are great. But go outdoors and let the shielding gas get blown away by a gust of wind and they are not worth much. I think most people learn to weld w/ stick and go on to use other welders to diversify their projects.MOST IMPOTRTANT IS CLEAN!!!!! !! Grind down what you want to weld and do not weld through rust, paint , mud or manure! You might not get certified for bridge work, but anyone who can identify what they are welding, use the correct rod at the right temperature on clean work with a little practice can look preety smart compared to your cousin who says " sure I can weld that for ya!" just my thoghts, mike
JerryU
01-07-2000 04:13:16
Look for your local school system adult education classes. Most offer it in night school
Once you buy a welder, just practice. If you are a hobbyest, a small welder that plugs into 115 volts will put 1/4" plate together, but if you are going to be building a lot you need a serious welding machine. But if you want to start out and putter around, you can do it for about $100 or less if you understand the limitations.
I have a small $100 machine I use for repairs around the barn, but if I need to build something, my Father in Law has a good sized Lincoln welder just down the road. Mostly, I just put piece a to piece b and make up small brackets and my little 100 amp buzz box works fine.
Just another opinion.
JerryU
CLOONEY
01-06-2000 18:19:06
Barney, MIG welding is the easiest to learn. If you enter "WELDING" in one of the search engines such as "YAHOO" there will be many sites on welding tips,hints & the usage of different welders etc. Also try this web site---http://home.att.net/~migwelding/index.html
Steve U.S. Alloys
01-06-2000 18:14:27
Hello Barney,
CB is right. A vocational school is great. If you don't have one then maybe the local high school or community college offers a welding class.
IMHO there is not a "Best" welding process to learn. They all have their proper place and area of best performance. As far as the most popular and easiest to master it has to be the wire feed welder.
Learning your metals is quite another thing in addition to learning to "run a pretty bead". I have had the priveledge in my 22 years in this business to meet some real artists. That's the level you achieve beyond "Good Welder".
Good luck, be safe and may the welding God's be with you.
catblaster
01-06-2000 17:37:52
Barney, I would try one of your local vocational schools. My personal opinion is to start on oxy-acety or stick, they are sometimes more forgiving and many of the lessons are valuable when you advance into tig and mig. Just my opiniion cause that's how I started.
