? Proper use of Feeler Gauge
Ken Reese
12-21-1999 17:23:01
I am reassembling my 1950 JD model B and have a question about the use of a feeler gauge.
This is in regard to checking the proper backlash in the power takeoff between the bevel gear and bevel pinoin/drive shaft. The manual says to use a feeler gauge to check for correct backlash (clearance)between the bevel and pinion gears. Recommend backlash is .006 to .010. When checking should the blade of the gauge go through the entire depth of the gear cogs? I have never done this before and want to be sure I have the proper backlash. There seems to be more clearance at the top. As the gauge goes further into the space between the cogs, the clearance is less. What is the proper procedure?
Thank you,
Ken Reese
e-mail: [email protected]
Tom R
12-24-1999 05:24:53
 Re: ? Proper use of Feeler Gauge in reply to Ken Reese, 12-21-1999 17:23:01
Ken:
As the others have already stated a dial indicator is the best method to use. However if you don't have access to one and must use a feeler gauge IMHO the way to do it is to turn the ring gear in the direction of travel until the pinion starts to turn and then measure the gap at a given point between the teeth (near the outer diameter of the gear). Then (with one hand on the pinion shaft) back off the ring gear in the opposite direction until you can feel the shaft wanting to move, now check the gap in exactly the same spot that you measured it before. The difference between the two readings will give you a rough idea of the backlash.
The depth of the pinion in relationship to the ring gear will have some effect on how the gears mesh and whether they mesh near the toe or heel all of this will change the actual gap, but the difference between the two gaps should give a useable reading. It has been a long time since I done it this way, so I hope my memory is accurate. We would also use white lead to coat the surface of the teeth and by turning the gears the contact pattern would be marked on the painted surface to allow you to judge if the pinion depth shims or adjustment needed to be changed.
Hope this help Tom R.
Paul R
12-22-1999 20:15:13
Someone has done this more than me and can give a simpler answer, lacking that, here's my atempt to cover all the bases. Backlash is the operating clearance between the gear teeth at their tightest point between wear faces. When you use the feeler guage, consideration should be given to any steps or deep wear on the wear faces of the teeth that might affect the application of feeler guage. A dial indicator may be more accurate, given correct setup. Judgement must be used to determine how to use feeler guage properly on worn gears.
Leon Miller
12-23-1999 20:18:44
 Re: Re: ? Proper use of Feeler Gauge in reply to Paul R, 12-22-1999 20:15:13
Ken Paul gave a good answer. Back when I did a lot of this type work, I was able to just rock the gears back and forth and feel when I had the correct backlash. With wear etc it is not possible to get correct reading with a flat feeler guage. Dial indicator is the way to go.
Since you want to measure backlash you would have to be measuring the spot of tightest gear mesh.
Good luck Leon
Fred Martin
12-24-1999 08:47:24
 Re: Re: Re: ? Proper use of Feeler Gauge in reply to Leon Miller, 12-23-1999 20:18:44
I always heard from the old timers that you could use a piece of paper and adjust the gears till it just cut the paper when running it between the ring and pinion gear.
