Lumber to replace barn walls?
Stooks
12-21-1999 12:46:10
What kind of lumber would be good to replace the horizonal boards on my barn?
ericc
12-31-1999 05:11:54
 Re: Lumber to replace barn walls? in reply to Stooks, 12-21-1999 12:46:10
I just spent the entire summer rebuilding a post and beam barn built around 1875. Had to jack it, dig and pour footings, and pour a concrete floor. I removed every single piece of barn-board siding, squared it off and then put it back using galvanized deck screws. What a project! I didn't know how much siding I would have to replace at the start, so I bought rough cut pine at the lumber yard to replace what I could not use. As it turned out, I was able to only have to use the new stuff for the three doors. My comment is that you have to go what you want for looks- do you want something that looks old or not. That may determine your choice.
Question- alot of barns in my area (Vermont) have a somewhat dark reddish/orangish look to them. I am told that years ago, creosote was applied to them to give them this look and to preserve them. Is that true? What could give that look these days?
thanks,
eric c
Fm..
12-23-1999 18:54:52
talk to your local small time sawmill operator. he should know what is best for siding in your area, and can usually cut it that day if its below 500 board foot, I think. might be 3 days or a week, depending on how big the order si, though
Corey
12-21-1999 13:26:05
What boards are you talikng about? Beams, siding, nailers?
Stooks
12-22-1999 12:31:03
 Re: Re: Lumber to replace barn walls? in reply to Corey, 12-21-1999 13:26:05
Siding - the uprights that you nail to are in good shape.
bbott
12-23-1999 10:07:41
 Re: Re: Re: Lumber to replace barn walls? in reply to Stooks, 12-22-1999 12:31:03
Sounds like you're rebuilding an old barn....
Are you asking what kind or what dimension ?
Really, what lumber you use is pretty well dependent on the following...
1) What part of the country you're in... What's available and cheap where you live.
2) What kind of decay/insect problems you have.... If you're not going to paint or treat it, you need something with natural insect/ weather resistance.
3) How the barn is framed.... 24" centers, 16" ??
4) What kind (if any) critters you're going to keep in the barn. Some like to chew on things.. If so you have to avoid paints/stains and other toxic stuff.
Most common answers...
Boards .... 4/4 x 6, 8 10 or 12.... or 5/4x same
DF. SYP, or whatever's in your area...
T1-11 Plywood siding.
Waferwood (OSB) siding.
A local lumberyard or your ag agent should be able to give you advice.
