Parts for westinghouse air compressor???
Joe
12-19-1999 19:46:52
I need a ring set for a Westinghouse 2 stage air compressor it is a 3 to 5 hp size. Anyone know of any sources out there or cost for a rebuild kit? Thanks
john victorino
01-20-2008 19:17:56
 Re: parts for westinghouse air compressor??? in reply to Joe, 12-19-1999 19:46:52
joe, southern parts 1-800-892-6189 ask for dave. they have parts for westinghouse compressors. all but what i need. hope this helps.
john victorino
01-16-2008 12:37:26
hi, i am looking for a piston for a westinghouse air compressor. does anyone know where i might find one. thanks for any help.
Eldon pavolini
12-23-2003 17:52:58
Looking for parts for a Westing House Model: IVC-1
S/N 459x2024 air compressor.
jerryJGC
12-19-2005 10:35:20
 Re: Re: parts for westinghouse air compressor??? in reply to Eldon pavolini, 12-23-2003 17:52:58
need info. and possible parts on westinghouse 4AWC air compressor pump. (Q) PUMP TURNS BUT NO AIR ? CAN YOU HELP? THANKS JERRY.
Roger Prosper
02-26-2000 00:05:15
If your westinghouse is a large enough model (ie industrial) there is a good chance that any compressor shop that uses jobber parts can locate a rebuild kit for you. A company called Independent Components Corp and another called Parts Service International specialize in supplying aftermarket compressor parts but they only sell to compressor companies, not end users. There is quite a long list of parts available in the ICC catalog for Westinghouse air compressors. These parts are as good as OEM in my opinion and I have never seen parts from either company fail due to poor workmanship. Often these parts are identical to OEM since they are purchased from the same manufacturers. Interestingly, all Westinghouse air compressors I have built have had poured (lead?) con rod bearings, with clearances set by shims between the rod and cap. They also had crank mounted plunger oil pumps. These units are very heavily built and last forever. If a rebuild fits your budget, they are well worth it.
Mike Harris
06-21-2003 14:51:35
 Re: Re: parts for westinghouse air compressor??? in reply to Roger Prosper, 02-26-2000 00:05:15
rebuild parts for westinghouse air compressor
Wimisa Austria Hr. Herman
09-29-2004 22:02:40
 Re: Re: Re: parts for westinghouse air compressor? in reply to Mike Harris, 06-21-2003 14:51:35
please your mail we have one inquiri for you
Myron Ridgeway
10-17-2002 14:47:52
I have a unit that was made by Westinghouse Air Bank and the engine on it I think is an International. Not sure. The only numbers I can find on this unit are Model 130RG1-E and a Serial # 273453
I am in need of a water pump for this unit, but don't know where to go and haven't had any luck in finding one yet. Any and all help you can provide would be great. I think this unit was built in early 1950. Only a guess for we do not have a manual on this unit. Still works great otherwise.
Randy Havlicek
11-25-2001 19:04:22
In finding this great sight, I,am pleased to see parts are available for Westinghouse air compressors. My question is, I had gotten a Two Stage model 2-YC from my father. It kinda sounds healthy but I really dont know. He had a Taiwan type 5 H.p. motor on it and it didnt seem to be working as I would expect for such a large pump. Can you please tell me A. on a single 30 gl or if I can tie 2 30 gl tanks together, what kind of CFM I may be able to expect and what size and RPM motor is reasonable for this pump? It,s got an 18" pulley. I really had thought this was a good sized compressor for home use. Thanks
mike acme iron works inc.
07-20-2000 09:33:37
i am looking for westinghouse air compressor model 5-yc 2-stage base or tank mounted.i can be reached between the hours of 6:30am to 3:pm monday thru friday pacific time.phone 626-448-0792
