Pump for fluid in tires.
Ken
12-18-1999 18:58:28
Where can I get a pump for pumping fluid out of tires or can I build one.
Paul
12-19-1999 09:52:41
 Re: Pump for fluid in tires. in reply to Ken, 12-18-1999 18:58:28
I used one of the little electric drill pumps that sell cheap in about any hardware store. It has garden hose fittings on it. You may also like one of those little "bleeder" fittings that screws on the tire valve. It will let you vent the air pressure that builds up as you pump the fluid back into the tire. You can let the air out by unscrewing the valve, but I'm a sucker for little gadgets like that. I don't know if the pump would hold up to daily use, but for an occasional tire repair it will work.
big jake
12-21-1999 07:01:11
 Re: Re: Pump for fluid in tires. in reply to Paul, 12-19-1999 09:52:41
gemplers catalog carries that junk 1-800-382-8473
