Sleeve puller
Big Mike
06-17-1998 20:16:10
Has anyone out there made a good,homemade
sleeve puller for an M? How so? Or is it better
to rent one from say, auto parts store? Mike.
Eddie Petty
06-18-1998 16:07:01
 Re: sleeve puller in reply to Big Mike, 06-17-1998 20:16:10
Assuming that the block is mounted in an engine stand, set your arc welder to the 200 amp range and using the largest rod that you have at your disposal, weld three or four vertical beads equally spaced about the cylinder's bore. Do all four cylinders then invert the block on the stand and walk away. Busy yourself doing something else and you will soon hear the liners hit the floor as they fall out due to the liners contracting from the heavy beads cooling. I've done this with countless diesel and gasoline engines. Good luck
