Blasting,Alternate methods and abrasives
Green Fever
11-24-1999 16:42:18
Does anbody out there use preasure washing for paint removal? Can I afford a washer with enough preasure to get the job done? What is a safe grit abrasive that is economicle to use?
DC Dale
11-24-1999 20:35:43
 Re: Blasting,Alternate methods and abrasives in reply to Green Fever, 11-24-1999 16:42:18
Getcher winter master catalogue from Northern Tool & Eq. On page 270, lowerleft corner, there is a sandblast att. for a pressure washer. I used one of these some years ago on rusty truck wheels, and it was very effective, but as I recall the sand consumption seemed high, maybe 100# per wheel. I am going to buy this one to do a multi-paint layered Airport tug i recently bought. I'll post backnext month with the results.....
GREN FEVER
11-24-1999 20:39:44
 Re: Re: Blasting,Alternate methods and abrasives in reply to DC Dale, 11-24-1999 20:35:43
THANKS DCDALE PLEASE DO.
Red1
11-26-1999 03:21:18
 Re: Re: Re: Blasting,Alternate methods and abrasives in reply to GREN FEVER, 11-24-1999 20:39:44
I go to the builders store and purchase fine builders sand and use it, about 3.50 per 50#. I fit starts cuttng too much cut your pressure or change orfice.
