Shop interior
Steve U.S. Allo
11-18-1999 14:05:44
I recently constructed a pole building and want to finish part of the inside to use as a shop area. Does anyone know of a good source for 2" 4x8 foam and 10' corrugated metal. I would consider seconds. If someone knows a better way to finish off the inside of a pole building I would appreciate any input. Thank you.
Steve U. S. Alloys
11-19-1999 06:10:07
 Re: shop interior in reply to Steve U.S. Alloys, 11-18-1999 14:05:44
Thanks Bob and Rick for your input. I do plan to use white metal everywhere but the welding area. Did you guys put your wiring in conduit on the outside or did you put it in underneath the wall covering next to the purlins? I'm leaning hard towards putting mine in conduit attached to the outside.
Bob
11-22-1999 15:23:30
 Re: Re: shop interior in reply to Steve U. S. Alloys, 11-19-1999 06:10:07
We ran ours in conduit on the inside so we would have clean walls. It doesn't make too much difference as long as you have plenty of boxes.
Bob
11-18-1999 15:54:42
When we built my Father in Laws shop we used Tuff-R, the foam board with aluminum covering thinking it would reflect the light for a brighter shop. After 6 months we replaced it with plywood covered with white panels. The white made the shop a lot brighter.
luke Pinder
01-26-2001 10:32:10
 Re: Re: shop interior in reply to Bob, 11-18-1999 15:54:42
Hi i am doing a project on interior shop design and was wondering if you could send me some info to help me with my project
RickB.
11-18-1999 14:25:34
If you are planning to do much welding, use light blue or gray from the floor up to at least 8' on the walls. These colors suck up welding flash much better than others, and still reflect your lighting sources well.
Dusty
11-21-1999 06:02:45
 Re: Re: shop interior in reply to RickB., 11-18-1999 14:25:34
If you are going to use steel on the ceiling, use perforated for sound deading, other wise you will think that you are in a cave.
Dusty MI
Steve U. S. Alloys
11-21-1999 07:29:25
 Re: Re: Re: shop interior in reply to Dusty, 11-21-1999 06:02:45
Thanks Dusty,
I didn't think of that. Makes good sense. My arc gun emits noise in the 114Db range. It would be like being in a cave with a jumbo jet. I should probably put up dry wall or acoustic tile on the ceiling.
Russ
11-22-1999 15:28:37
 Re: Re: Re: Re: shop interior in reply to Steve U. S. Alloys, 11-21-1999 07:29:25
Steve, have you heard of cementitious backer board? Around my area it goes by the name of Durock or wonderboard. Although it is made as an underlayment product for ceramic tile, it has outstanding thermal properties regarding high heat and flammability,especially when you finish the seams between sheets with thinset mortar as recommended by the manufacturer. Because it is made from cement, it also has good acoustic properties, and it takes paint very well. It also seems to stand up to impact much better than steel and it is electrically non-conductive. It`s an all around excellent product for a welding shop. Another place it works well is under the catalytic converter of any vehicle parked on a wood floor, such as the second story of many barns. In my area, it`s also cheaper, per sq ft, than painted steel.
