Clutch (?) problem
Rob
11-08-1999 05:16:37
I think the clutch on my 8N/9N seems to have gone out all at once. It had been working fine, as it was replced 3 yrs ago. I parked it as usual a week ago, and I went out to start it yesterday and I apparently have no contact between the clutch plate and flywheel. The PTO turns very slowly, or not at all, and I can shift between all the gears without depressing the clutch (and the tractor doesn't move). Can anybody tell me what may have happen? Thanks in advance, Rob.
Leon Miller
11-08-1999 16:58:58
 Re: Clutch (?) problem in reply to Rob, 11-08-1999 05:16:37
Rob. Do you have any resistance when you press your clutch pedal? If you do feel the normal pressure of the pressure plate springs then it appears the clutch disk has broken out the splines from the disc.
