Dry-ice blasting??
Pete Peterson
11-05-1999 23:42:29
Anyone ever heard of dry-ice blasting? Saw a contractor's trailer that advertised it. I'd never heard of it before. Just curious.
Tony
03-24-2000 08:39:19
 Re: Dry-ice blasting?? in reply to Pete Peterson, 11-05-1999 23:42:29
Check out www.coldjet.com for detailed information with pictures too.
Tim
11-28-1999 15:14:33
Yes, seen it used to clean weld flash and dust from automation and robots in a Ford Motor Co. assembly plant where they weld the body (bodyshop)
Russ
11-06-1999 22:31:32
I work in a nuke plant where a great deal of decontamination of tools and equipment is done on a regular basis. The laborers doing most of this work use dry ice blasting as a high production technique. It`s very impressive. I`ve seen it remove paint and oil from even soft metals like aluminum, with no damage to the item being cleaned, and in our case, it doesn`t generate any additional radioactive waste. It even works well on light rust.
Brian Currie
01-23-2004 06:52:57
 Re: Re: Dry-ice blasting?? in reply to Russ, 11-06-1999 22:31:32
I have a dry ice blasting company in alberta. The process works very well at removing process contaminants. Works on removing pitch (glue and wood prodocts in wood processing plants), cleaning tube sheet welds and other welds prior to Non Destructive testing, preparing process equipment prior to bolt up after plant turn arounds (to remove bio films and rust plooms). The equipment is very portable and can be set up at the location of equipment that is being cleaned.
christophe
04-16-2004 09:41:24
 Re: Re: Re: Dry-ice blasting?? in reply to Brian Currie, 01-23-2004 06:52:57
Goodday,
I happen to read you are a dry ice blaster.
Nice to know you. Are you interested in alternative dry ice blasting machines?
We are manufacturer of CRYONOMIC & CRYOBLAST DRY ICE MACHINES.
If so, feel free to contact us in Europe!
Christophe Cuigniez
www.cryonomic.com
