9N FORD HYDRAULICS
Larry Lustfeldt
06-12-1998 09:37:36
RESTORED OLD FORD LAST WINTER, DID NOT REBUIL HYD PUMP AND SEATS APPERED OK. ALL RUNNING SMOOTH, THEN A COUPLE WEEKS AGO, I STARTED GETTING KNOCKING IN HYD. AREA WHEN LIFTING HEAVY LOAD. I PUT IN PUMP ON AND LEFT MOUNTING PLATE BOLTS LOOSE , WITH PTO SHAFT INSTALLED AND TURNED OVER ENGING SEVERAL TIMES TO ALIGN PUMP. ANY THOUGHTS ON WHAT IS CAUSING KNOCKING?
Matt
06-18-1998 09:31:52
 Re: 9N FORD HYDRAULICS in reply to Larry Lustfeldt, 06-12-1998 09:37:36
What the problem could be is the weight of the load.
The catagory one hitch is rated only for 1500 pounds.
Jim
06-13-1998 10:57:30
: RESTORED OLD FORD LAST WINTER, DID NOT REBUIL HYD PUMP AND SEATS APPERED OK. ALL RUNNING SMOOTH, THEN A COUPLE WEEKS AGO, I STARTED GETTING KNOCKING IN HYD. AREA WHEN LIFTING HEAVY LOAD. I PUT IN PUMP ON AND LEFT MOUNTING PLATE BOLTS LOOSE , WITH PTO SHAFT INSTALLED AND TURNED OVER ENGING SEVERAL TIMES TO ALIGN PUMP. ANY THOUGHTS ON WHAT IS CAUSING KNOCKING?
