Parts Washer Solvent
DonS
10-07-1999 13:37:51
I just purchased a parts washer at a auction, now can anyone suggest a good solvent that I can use in it?
Big D
11-26-1999 09:22:48
 Re: Parts Washer Solvent in reply to DonS, 10-07-1999 13:37:51
I've had excellent results with the Citrus based stuff, works good and doesn't smell bad either.
When I worked for an Auto Parts store we had a lot of Parts Washers returned as defective because guys were trying to use carb cleaner in them, the pump just doesn't run when the plastic impeller is melted by the carb cleaner.
buck
10-25-1999 16:59:27
DonS Had a homebuilt partswasher for 25+ years and on the advice of a person in the business I use VARSOL. Clean the washer (30 gal. drum) every year or so and add VARSOL as needed.
JDBob
10-09-1999 20:46:24
I use some stuff in mine that I pick at at the parts store. It's made my GUNK it's in a blue and white can, comes by the gallon. You have to mix it with Diesel Fuel. It does a really good job. Not only does it clean parts but I've found that if you have a part that is rusted stuck you can let it soak in that stuff for a while and it helps to get it loosened back up pretty good.
Mike
10-17-1999 20:29:14
 Re: Re: Parts Washer Solvent in reply to JDBob, 10-09-1999 20:46:24
Dollar for Dollar I have had the best luck with mineral spirits. (Paint Thinner). It is cheap, about $1.75 a gallon at the local home improvement store and cuts the goo just fine. Not as stinky as diesel fuel, either. Plus, with a little shot of air it evaporates right off the parts leaving them clean and dry. Good luck
Diesel Fuel
10-09-1999 09:05:08
For all around you just can't beat diesel fuel. It is'nt in short supply and it cleans pretty good.
Clint
10-17-1999 19:56:03
 Re: Re: Parts Washer Solvent in reply to Diesel Fuel, 10-09-1999 09:05:08
What about that unchristly stench?
Ernie
10-07-1999 15:49:42
A. Contact your safety Kleen rep. He will pick it up when it is spent and propely recycle it.
A'. At the plant we have had good luck with a citrus based degreaser and water. Wipe cleaned parts with clean oil immediately after cleaning.
B. Mineral spirits or kerosene. What will you do with it when it is full of grease and dirt?
C. Fuel oil. See B above.
Wear rubber gloves and have good ventilation with any of the above. The solvent will remove the oils from your skin, raise hell with liver and kidneys and you can't smell the nasties. Make sure the lid has a fusible link so it will close automatically in case of a fire. Don't locate near a welding center and install a good sized fire extingusher by an outside door.
Clint
10-17-1999 20:26:28
 Re: Re: Parts Washer Solvent in reply to Ernie, 10-07-1999 15:49:42
A: Safety Kleen is prohibitvely expensive to all but commercial shops who are forced to cowtow to the EPA.
B: Also expensive and in some cases unacceptably corrosive.
C: Mineral spirits or kerosene work pretty well,
but are a little oily, thus their ability to cut oil is somewhat limited.
D: Diesel is really oily, and really stinky!
E; Why not go to your local oil jobber and tell him you want a 30 gal drum of parts washing solvent? More expensive than kerosene or mineral spirits, (about$4/gal), but dryer so it will last longer (absorb more oil) and less volatile. Disposal of c,d,& e is easy. Dump it in your waste oil. That's what it ends up mostly being anyway. In our state, law requires that anyone selling oil or filters must accept both for recycling.
John
10-13-1999 03:46:45
Safety Kleen is the only way to go for parts cleaner.
