Pipe bender
farmer
06-05-1998 08:35:07
Bought a portable hydraulic pipe bending press from Harbor Freight last year and have been very happy with it. Was just a little over $100. Bends without crimping and have found it will also bend exhaust tubing. If any one has looked and wondered it is a good tool.
Has anybody had experience with these cheap 20 gal. parts washers ? Are they any good or a waste of $$ ?
Mark T
06-05-1998 17:40:53
 Re: pipe bender in reply to farmer, 06-05-1998 08:35:07
: Bought a portable hydraulic pipe bending press from Harbor Freight last year and have been very happy with it. Was just a little over $100. Bends without crimping and have found it will also bend exhaust tubing. If any one has looked and wondered it is a good tool.
: Has anybody had experience with these cheap 20 gal. parts washers ? Are they any good or a waste of $$ ?
We use a service (Safety Kleen) in our shop to avoid waste disposal problems (besides being convenient) but before that we had a washer like the one you describe that came from Northern Hydraulics.It was cheap and worked just fine.Hope this helps.Mark
Joe M
11-19-1998 16:28:42
 Re: Re: pipe bender in reply to Mark T, 06-05-1998 17:40:53
: : : Bought a portable hydraulic pipe bending press from Harbor Freight last year and have been very happy with it. Was just a little over $100. Bends without crimping and have found it will also bend exhaust tubing. If any one has looked and wondered it is a good tool.
: : Has anybody had experience with these cheap 20 gal. parts washers ? Are they any good or a waste of $$ ?
: We use a service (Safety Kleen) in our shop to avoid waste disposal problems (besides being convenient) but before that we had a washer like the one you describe that came from Northern Hydraulics.It was cheap and worked just fine.Hope this helps.Mark
I have a question about the pipe bender that maybe you can help me with.
I was looking to buy the bender that you have, but I need to know what the radius or diameter of the bend is for steel tubing 3/4" and 1" O.D..
I build go-cart frames and need a small radius of approx 3" (6" dia. on a 180 degree bend). I know the inserts are adjustable, but there is no mention in the add about radius. A conduit bender will work, but the radius is too large for what I need. If you could e-mail me with that info I would greatly appreciate it.
Thanks in advance..... Big Joe!
Mike
06-09-1998 13:08:03
Got something like it, works fine.
Someday you'll have to replace the solvent pump and will have to be carefull what you use because the pumps that come with the units look like goldfish pool pumps (for water) but are not designed to be used with solvents !!!
