Ford 700 fuel pump pressure
sam
06-04-1998 16:26:52
need help with for operating pressure for ford 700 diesel
Diesel Dan
06-04-1998 19:28:25
 Re: ford 700 fuel pump pressure in reply to sam, 06-04-1998 16:26:52
If it's the Roosa Master type pump you should have about 8 psi minimum at cranking and 60 to 75 psi at wide open throttle. Check pressure on the end plate at the (out) end. It should have a 1/4" pipe plug in it. Note : higher fuel pressure does not increase fuel output. These pumps are well known for having low cranking pressure.
Good Luck,
Diesel Dan (the pump man)
