Penetrating Fluid
jcj
09-18-1999 08:03:22
I was wondering what you guys would consider the best Penetrating Fluid you have found?
This has caused quite a few debates in the back of the shop and I would like a few more opinions.
Thanks!
Dieseldog ONT,CAN
02-12-2001 14:18:14
 Re: Penetrating Fluid in reply to jcj, 09-18-1999 08:03:22
JCJ Try the best,Howes Lubricator in spray or Mac Tools sells it by the gallon,(a little thicker in the Mac gallon)as it doesnt evaporate,has low flammability,penetrates excellent and has a pleasant cinimon scent.Its so highly refined its no longer classed as a solvent which makes it safe to use on plastic and rubber.I even find it makes a excellent air tool oil. Try it you,ll like it! Good Luck Dieseldog!
Robert
09-29-1999 07:20:14
I once had a 1940's Whitcomb switching locomotive, and ended up with diesel fuel in the crankcase.
I saved the mixture, and it works wonders on rusty, stuck parts. Wish I knew the ratio!
Louis G
09-24-1999 23:04:56
Justice Brothers JB-80 "TWICE AS GOOD"
John
09-21-1999 19:26:04
PB Blaster or Kroil are the two best.
Otis
09-18-1999 19:28:02
I like Aero Kroil
Rick
09-18-1999 18:13:24
I like Kano Kroil Oil. It seems to get in and help loosen tight rusted fasteners.
Kano Kroil+Graphite=Kano Penephite
09-19-1999 07:05:02
 Re: Re: Penetrating Fluid in reply to Rick , 09-18-1999 18:13:24
Was surprised to see something better than Kroil!!! Kano makes penephite too, once it and you get the part/bolt/nut moving, the graphite keeps it moving freely...amazing. I have not tried the Kano Kroil+Silicone yet, but will. I am expecting to be amazed again.
Paul R
Big mike sez....
09-18-1999 16:04:42
P.B. Catylist ( B' Laster) Makes WD-40 look like water!
Art
09-18-1999 17:08:08
 Re: Re: Penetrating Fluid in reply to Big mike sez...., 09-18-1999 16:04:42
Is that Gibb's as good as they would have you believe? Mac Tools sells a product made by Howe's that works real good, and it comes in qts. and gallons instead of spray cans.
Robert(AL)
09-26-1999 07:58:04
 Re: Re: Re: Penetrating Fluid in reply to Art, 09-18-1999 17:08:08
If you can stand the smell, try regular carburator cleaner. It's the best on the market for cutting rust. A friend of mine runs a small engine shop and keeps the cleaner in a regular oil can. It's the best!
I agree
09-27-1999 16:15:28
 Re: Re: Re: Re: Penetrating Fluid in reply to Robert(AL), 09-26-1999 07:58:04
works very good
