Welders
lh
09-09-1999 20:01:43
I am in need of some advice.I am considering buying a welder to have around the garage,but i notice there are arc,tig,mig,and wire welders,i no nothing about welding,could someone suggest what would be the best and easiest to use.
Thanks LH
Steve
09-22-1999 14:53:48
 Re: welders in reply to lh, 09-09-1999 20:01:43
You can learn a lot from a manufacturers rep/welder if you are open minded enough to listen. Doesn't cost a thing sir.
Ben
01-29-2001 21:28:04
 Re: Re: welders in reply to Steve, 09-22-1999 14:53:48
Dear Sir, As a former Ag.Instructor who taught high school students to weld (Stick first). I
would recommend you seek out a class or friend who is very experienced to get you started. I think stick welders would probably serve your needs the best for all around repair or light to medium construction. By the way, I just finished up my first steel framed building. 24x 36 using an antique Birdsell welding machine that I think belonged to my wife's grandfather. It's still going strong after many many years. It is wired 220 volt and the plate says it requires 30 amps.
Good luck. Be sure to follow all safety precautions and always inspect the lenses before
striking your arc.
Steve
09-20-1999 15:28:11
Wire welders are by far the easiest to use. If you can caulk a window you can wire weld. ( Also known as MIG or GMAW) You will want to set it up for steel I assume. They are not practical if you weld several different types of metals as you need different wires and gases for many. For steel you can use flux cored wire for dirty or outdoor projects. A novice welder would also benefit greatly from a electronic filter helmet. I have extensive experience in welding repair products and will gladly answer your questions or advise.
STEVE IS A SALESMAN NOT A WELDER
09-21-1999 19:46:42
 Re: Re: welders in reply to Steve, 09-20-1999 15:28:11
Chappy
09-10-1999 18:09:08
IH:
A good shop type arc welder i.e. Lincoln 225 amp
ac/dc is hard to beat. It will allow you to work on light and heavier projects while learning. You can always upgrade to a nice wire feed MIG welder later. Tig would be used if your doing aluminum projects and stainless steel. I just bought a nice portable Lincoln 200 welder on a trailer for $300, so you don't have to spend that much to get started. You might also want to consider taking a course at your local community college.
Good Luck
Chappy
Ernie
09-10-1999 15:19:43
what are you welding, sheet metal, angle iron, steel, stainless etc.
